QUOTE(Mark Henry @ Jul 14 2009, 04:41 AM)
Easy way to line things up is to bolt everything including the (stock) muffler togetther, Still won't perferct so it may need some tweaking, bending, clamps, etc.
If you use the stock muffler it should keep things straight. Tack it up then take it off and weld.
I have an old jig engine (empty block, just old cylinders and heads w/good exhaust studs) and a scrap trans, that I set upside down for a jig.
You shouldn't need to weld up the seams, if you smell exhaust you have an exhaust leak....just like if the cab is filling with smoke you have an oil leak.
Welding the clamshell may be tricky as it's very thin SS.
Thanx for the tip - as noted in reply to Andy, the engine & transaxle will be out, so it can serve as the jig.
The reason I want to seal them off, is that every time a small oil leak comes up - & all 914s eventually get them, it gets sucked/thrown into those gaps then cruds them up, as can be seen in what the seller hasn't cleaned up on this used set before selling it to me!
Also, small amounts of exhaust gases get sucked in there via the airstream, which can be enough to give mild cases of carbon-monoxide poisoning. If you've ever had headaches while driving your 914 when using the heater, that's why!
According to my long time factory trained 914 mechanic Hans in Huntington Beach CA, that was always one of the biggest complaint he had from 914 owners, along with oil leaks!
Looking at the current state of my OE HE's now - mine was probably starting by the time I put it into storage in my SoCal garage in 5/85, but our warmer climate probably saved me form having to use them much!
This is the end of one - all 4 ends are bad + holed along the shroud at several places! Although the SS shouldn't rust away like these end, I do want to eliminate the gaps if I can & it's safe to do so.
One end of one OE HE:
