944 Question, Fan stays on |
Randal |
Jul 19 2009, 02:50 PM
Advanced Member Group: Members Posts: 4,446 Joined: 29-May 03 From: Los Altos, CA Member No.: 750 |
I know this is off topic, but just looking for help. On Friday I drove my son's 944 down to Costco. It was a hot day. The fan stayed on when I left the car to go into the store and it was still on when I returned. Note: Operating temperatures were mid range, which is what I'd expect, given that a new radiator was put into this car. When I got home the fan wouldn't go off, unless I unplugged it. Another data point: The second fan wasn't on, even though I had been using the AC. So I read one of the repair manuals and they suggested, if the fan remained on, that the coolant switch (in the radiator) was faulty. So got a new switch, took the fan assembly out of the car and swapped out the coolant switch. I also tested both fans and they work. So I put the fan assembly back into the car and when I reconnected the power, with the car cold, the fan went on. I'm not sure what to check next, but any suggestions will be appreciated. __________________ Randal www.barrickpickeringracing.com |
jasons |
Jul 19 2009, 06:12 PM
Jackstand Extraordinaire Group: Members Posts: 2,002 Joined: 19-August 04 From: Scottsdale, AZ Member No.: 2,573 Region Association: None |
I can't remember if my problem was exactly the same as yours, I think I just had a fan that didn't run. On my old 89 S2, there was a bad resistor up under the cowl. Mine had 2 really big resistors to regulate fan speed. Honestly, when I saw the wiring to them it kind of scared me, because the insulation was all dry and cooked. My resistors were on the passenger side under the cowl. IIRC you have to pull the battery to get them. I don't know if this was the same for all years.
jcd914 |
Jul 20 2009, 06:45 PM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
Probably the cooling fan relay is stuck, not real uncommon on 944's. If you have a wiring diagram you could trace out the fan circuit and see if anything else other than the radiator switch operates the relay or the easier method, swap the relay with a known good part.
What year 944? Good luck Jim |
scotty b |
Jul 20 2009, 07:01 PM
rust free you say ? Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None |
Probably the cooling fan relay is stuck, not real uncommon on 944's. If you have a wiring diagram you could trace out the fan circuit and see if anything else other than the radiator switch operates the relay or the easier method, swap the relay with a known good part. What year 944? Good luck Jim (IMG:style_emoticons/default/agree.gif) Clarks garage will have the info you neeed to check it out. |
Randal |
Jul 20 2009, 07:59 PM
Probably the cooling fan relay is stuck, not real uncommon on 944's. If you have a wiring diagram you could trace out the fan circuit and see if anything else other than the radiator switch operates the relay or the easier method, swap the relay with a known good part. What year 944? Good luck Jim I have a good used relay and now know where it goes. Also found a blown fuse, number 3 controlling the fan motors, so maybe the relay blew the fuse. I'll pop in a new fuse and then see what happens. If the fuse blows then I'll swap out the relay next. Thanks. |
mudfoot76 |
Aug 28 2009, 12:47 PM
Currently teenerless :-( Group: Members Posts: 946 Joined: 18-March 04 From: Carmel, IN Member No.: 1,814 Region Association: None |
+1 on checking the fan relay. I don't have experience on a 944, but in working on my friend's 968 with him, his radiator fans would do the same thing. Replaced the relay and the fans now function normally.
grantsfo |
Aug 28 2009, 09:27 PM
Arrrrhhhh! Group: Members Posts: 4,327 Joined: 16-March 03 Member No.: 433 Region Association: None |
I have conducted root cause analysis on this problem. I conclude root cause is, ...its not aircooled. Sell said 944 and buy son a 914.
Randal |
Aug 29 2009, 02:47 PM
r_towle |
Sep 5 2009, 12:36 PM
Custom Member Group: Members Posts: 24,574 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
I am awaiting your diagnosis.
Please share... Our issue is the fan wont come on. I rigged a toggle switch. Rather not have to remove the whole raidator to get a stupid thermo switch in...poor design... Rich |
Lo-Fi Version | Time is now: 19th May 2024 - 04:31 AM |
