Syncos and gaskets, Best place to buy??? |
tracks914 |
Jul 22 2009, 09:35 AM
Canadian Member Group: Benefactors Posts: 2,083 Joined: 15-January 03 From: Timmins, Ontario, Canada Member No.: 153 Region Association: None |
I did my tail shifter about 5 years ago and it has work flawlessly ever since.
On my new (36 year old) car I replaced all the seals since it was out of the car. I hoped that since it only had 42K on it the syncros would be OK. Wrong. I now have to change 1st & 2nd. I don't need a whole gasket kit with seals ( the ones in it don't even have 100 miles on them) Where can I buy just the gaskets I need and 2 syncros?? BTW PP and AA seem to only sell complete gasket kits. Tx |
underthetire |
Jul 22 2009, 09:54 AM
I bought a gasket set on evil bay. 35 bucks. You can according the the manual, flip first gear syncro over and use the other side. I ordered all my syncros through AA. PP did sell just the tail cover gasket. You should contact the evil one.
Mark Henry |
Jul 22 2009, 12:38 PM
Just contact the good (and now real) Doctor. Hurry before he realizes he makes more money at work.
Dr Evil |
Jul 22 2009, 12:58 PM
I have what you need most likely (IMG:style_emoticons/default/smile.gif)
gothspeed |
Jul 22 2009, 03:05 PM
Senior Member Group: Members Posts: 1,539 Joined: 3-February 09 From: SoCal Member No.: 10,019 Region Association: None |
My GB pops out of 4th gear on deceleration only ...... would this be fixed with new syncros??
The GB shifts fine and works fine otherwise (IMG:style_emoticons/default/smile.gif) |
Dr Evil |
Jul 22 2009, 03:10 PM
Typically yes, but you must ask yourself, "Why the hell would 4th gear, a gear normally practically in like new condition in 30 yr old gear boxes, be a failure point in my box?" Check your linkage. If that is fine then I would bet that your box had been opened before and assembled incorrectly. You will likely need a slider, sychro band and teeth.
gothspeed |
Jul 22 2009, 04:44 PM
I was thinking the same thing Dr E .... (IMG:style_emoticons/default/ohmy.gif) ........... so I replaced all shifter linkage bushings and engine mounts thinking it would solve the poping out problem ...... the car shifts better but still pops out of 4th .... (IMG:style_emoticons/default/sad.gif)
0396 |
Jul 22 2009, 11:58 PM
Advanced Member Group: Members Posts: 2,046 Joined: 13-October 03 From: L.A. Calif Member No.: 1,245 Region Association: Southern California |
I don't need a whole gasket kit with seals ( the ones in it don't even have 100 miles on them) Where can I buy just the gaskets I need and 2 syncros?? Tx Your local Porsche dealer can order you the one you need..aks me how I know (IMG:style_emoticons/default/biggrin.gif) |
Dr Evil |
Jul 23 2009, 01:01 AM
Really? That is news to me. Great news! How much was it?
gothspeed |
Jul 23 2009, 12:43 PM
Dr Evil |
Jul 23 2009, 12:53 PM
There are 3 parts to consider and it is not possible to tell you which is the culprit; slider, band, teeth
The odd location only serves to complicate a diagnosis without laying eyes on the stack. |
mburkhart |
Jul 23 2009, 01:19 PM
Member Group: Members Posts: 112 Joined: 3-July 05 From: Chester, MD Member No.: 4,364 Region Association: MidAtlantic Region |
I'm thinking about doing some transmission work as well. My issue is that I cannot shift into 2nd gear without crunching unless I ease the shifter into gear very slowly. I believe this is due to a worn out synchro. Clutch and every other gear appears to be fine. Would I just want to replace the 2nd gear synchro?
Perhaps related - I also sometimes have trouble getting into 1st gear from a stop, but I have not yet replaced all of the shift bushings (I plan to soon). Thanks for any advice! |
gothspeed |
Jul 23 2009, 03:37 PM
Dr Evil |
Jul 23 2009, 09:27 PM
There are 3 parts to consider and it is not possible to tell you which is the culprit; slider, band, teeth The odd location only serves to complicate a diagnosis without laying eyes on the stack. Ok should I get this gear stack out and take some pictures? YES (IMG:style_emoticons/default/slap.gif) (IMG:style_emoticons/default/wink.gif) |
Lo-Fi Version | Time is now: 17th May 2024 - 05:02 PM |
