installing rings!, I found a crack in the piston wall. |
JOE M |
Jul 24 2009, 11:43 AM
Member Group: Members Posts: 293 Joined: 27-August 07 From: N.H Member No.: 8,042 Region Association: None |
I think I know the answer but hopefully I am wrong. I was installing new rings and found that 1 piston had a chunk missing from the wall (see pic). Is there any hope for this piston or is it dead.My guess is that it is trash but can I replace a single piston or do I have to replace all 4?
underthetire |
Jul 24 2009, 12:02 PM
I think I know the answer but hopefully I am wrong. I was installing new rings and found that 1 piston had a chunk missing from the wall (see pic). Is there any hope for this piston or is it dead.My guess is that it is trash but can I replace a single piston or do I have to replace all 4? If one chunk came out, whats to stop more from coming out at 6K RPM. Plus i think you will break a ring. Junk IMO. |
Jake Raby |
Jul 24 2009, 12:11 PM
Throw it away...
JOE M |
Jul 24 2009, 12:37 PM
man 1 thing after another. I cant catch a break.But the second part of my question was do I need to buy all new cylinders/pistons or just the 1?Regardless it sucks because im on a huge budget but I want to do what right.
jcd914 |
Jul 24 2009, 01:50 PM
You do not need to replace the complete set of pistons, 1 piston knows nothing of the others. You will need a piston that matches you others though.
It will need to have the correct piston to cylinder clearance, the correct weight to match the rest and a matching dish, valve relief's, pin height and anything else that will affect the compression. You don't see a lot of single pistons for sale so it might be easier to just get a matched set. Jim |
JOE M |
Jul 24 2009, 02:02 PM
You do not need to replace the complete set of pistons, 1 piston knows nothing of the others. You will need a piston that matches you others though. It will need to have the correct piston to cylinder clearance, the correct weight to match the rest and a matching dish, valve relief's, pin height and anything else that will affect the compression. You don't see a lot of single pistons for sale so it might be easier to just get a matched set. Jim I did see complete sets for 1.7 running around $200.It just sucks that I will need to buy a whole set.And on top of that my freaking windshield cracked last week.I started to pull off the molding and when I came home from work there was a crack.This freaking car is killing me but I am on a personal quest to get this thing running.I just dont have a ton of money so thats why I asked if there is anything that can be done for the piston.Deep down I already knew what the answer was but I guess I was hopping that someone would say something like that happens all the time--get a little jpb weld and your in business.LOL WISHFULL THINKING. |
jcd914 |
Jul 24 2009, 02:42 PM
Have you measured the piston to cylinder clearance?
Do you know which 1.7 pistons you have? You could post a WTB ad with the info you have and maybe someone has a piston to match. I have a set of 1.7 P&C's I'll never use but 3 of the 4 are still on the engine and it is VW 411/412 engine. I have no clue how those P&Cs would compare to a set for a 914. Of my 3 914s the only one without a cracked windshield is the one without a windshield. (IMG:style_emoticons/default/sad.gif) Jim |
Mark Henry |
Jul 24 2009, 02:49 PM
I have two used 1.7 P&C sets (different dish) in OK condition. I may have a couple of singles, but I'd have to check.
Shipping a whole set (from Canada) costs about $70 I think. |
JOE M |
Jul 24 2009, 02:51 PM
JOE M |
Jul 24 2009, 02:57 PM
Have you measured the piston to cylinder clearance? Do you know which 1.7 pistons you have? You could post a WTB ad with the info you have and maybe someone has a piston to match. I have a set of 1.7 P&C's I'll never use but 3 of the 4 are still on the engine and it is VW 411/412 engine. I have no clue how those P&Cs would compare to a set for a 914. Of my 3 914s the only one without a cracked windshield is the one without a windshield. (IMG:style_emoticons/default/sad.gif) Jim So cracked windshields are common???? I did not measure the distance because they were already shimed.I probably should remeasure and shim if needed.To be honest the only in depth thing I know about this engine is that it a 1.7. It had real low compression when I bought it. So far I bought new carbs and now rings. |
Mark Henry |
Jul 24 2009, 03:05 PM
I have two used 1.7 P&C sets (different dish) in OK condition. I may have a couple of singles, but I'd have to check. Are you selling them?If so how much----- $20 for my time....actual post charge. BTW that's slow post, takes about 2weeks, Just the 4 pistons shipping would be cheaper (or faster). Post a pic of your tops, I'll see if I have the same, then you might have a couple extra pistons |
Mark Henry |
Jul 24 2009, 03:17 PM
Ok I have a set of dish P&C, and just the pistons with a dome top.
I'm sure I had another set, but I don't see it. |
JOE M |
Jul 24 2009, 03:18 PM
I have two used 1.7 P&C sets (different dish) in OK condition. I may have a couple of singles, but I'd have to check. Are you selling them?If so how much----- $20 for my time....actual post charge. BTW that's slow post, takes about 2weeks, Just the 4 pistons shipping would be cheaper (or faster). Post a pic of your tops, I'll see if I have the same, then you might have a couple extra pistons I dont know if these pics help but here are a couple. |
JOE M |
Jul 24 2009, 03:20 PM
1 more sorry.
JOE M |
Jul 24 2009, 03:48 PM
So is it possible to tell any details about this engine by pics I have posted?
tat2dphreak |
Jul 24 2009, 03:59 PM
the engine number is on top, by the oil filler, that's the only number that matters. (IMG:style_emoticons/default/sad.gif)
JOE M |
Jul 24 2009, 04:03 PM
w0114127 is the only number on top. Its actually by the back not the oil filler.
tat2dphreak |
Jul 24 2009, 04:08 PM
1.7 engine, early one
66x90mm |
JOE M |
Jul 24 2009, 04:10 PM
Mark Henry |
Jul 24 2009, 04:13 PM
The top of your old piston....is it an innie or outie...dome or dish?
Lo-Fi Version | Time is now: 17th May 2024 - 07:58 PM |
