| kenshapiro2002 |
Jul 26 2009, 03:32 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,486 Joined: 23-July 09 From: Bawlmer, MD Member No.: 10,598 Region Association: MidAtlantic Region |
My "new" 1970 914 has a working speedo, but the odometer isn't working. The seller said it's most likely an internal gear that he's seen folks replace rather easily. Any experience out there on this one? Also, the trip odometer isn't working and the reset button seems not to exist. It's not under the dash.
??? Ken |
| t collins |
Jul 26 2009, 04:47 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,270 Joined: 21-March 06 From: Virginia Member No.: 5,754 Region Association: None |
I had the same problem and was able to fix, go to Pelican Parts a d you'll find step by step instructions.
| ejm |
Jul 26 2009, 04:50 PM
I can see the light at the end of the tunnel ![]() ![]() ![]() ![]() Group: Members Posts: 2,717 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
The gear usually does not need replacement. The fix is to disassemble the head and knurl the shaft where the gear is so the shaft turns with the gear as it did when new. The trip counter should work once the odometer is fixed. The reset is a knob not a button. Should be under the dash to the right of the steering column and the knob will only turn one way.
| kenshapiro2002 |
Jul 26 2009, 07:42 PM
I swear...I have no knob either. (IMG:style_emoticons/default/WTF.gif)
Ken The gear usually does not need replacement. The fix is to disassemble the head and knurl the shaft where the gear is so the shaft turns with the gear as it did when new. The trip counter should work once the odometer is fixed. The reset is a knob not a button. Should be under the dash to the right of the steering column and the knob will only turn one way. |
| jsaum |
Jul 26 2009, 07:52 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 530 Joined: 12-June 07 From: Everett, WA Member No.: 7,809 Region Association: None |
I swear...I have no knob either. (IMG:style_emoticons/default/WTF.gif) Ken The gear usually does not need replacement. The fix is to disassemble the head and knurl the shaft where the gear is so the shaft turns with the gear as it did when new. The trip counter should work once the odometer is fixed. The reset is a knob not a button. Should be under the dash to the right of the steering column and the knob will only turn one way. The knob is attached to a shaft with a flat on it which is attached to a cable going to the trip counter. It should be under the knee pad to the right of the stering wheel. If it's not there reach up and see if you can feel the cable it may be up under the dash. I just pulled mine apart and got it working it was rusted and wouldn't turn. |
| kenshapiro2002 |
Jul 26 2009, 07:55 PM
I was thinking the same thing...gotta get out there, on my back, with a flashlight!
Ken I swear...I have no knob either. (IMG:style_emoticons/default/WTF.gif) Ken The gear usually does not need replacement. The fix is to disassemble the head and knurl the shaft where the gear is so the shaft turns with the gear as it did when new. The trip counter should work once the odometer is fixed. The reset is a knob not a button. Should be under the dash to the right of the steering column and the knob will only turn one way. The knob is attached to a shaft with a flat on it which is attached to a cable going to the trip counter. It should be under the knee pad to the right of the stering wheel. If it's not there reach up and see if you can feel the cable it may be up under the dash. I just pulled mine apart and got it working it was rusted and wouldn't turn. |
| saigon71 |
Jul 26 2009, 08:02 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,020 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region
I swear...I have no knob either. (IMG:style_emoticons/default/WTF.gif) Ken The gear usually does not need replacement. The fix is to disassemble the head and knurl the shaft where the gear is so the shaft turns with the gear as it did when new. The trip counter should work once the odometer is fixed. The reset is a knob not a button. Should be under the dash to the right of the steering column and the knob will only turn one way. The knob is attached to a shaft with a flat on it which is attached to a cable going to the trip counter. It should be under the knee pad to the right of the stering wheel. If it's not there reach up and see if you can feel the cable it may be up under the dash. I just pulled mine apart and got it working it was rusted and wouldn't turn. Follow this Pelican technical article. http://www.pelicanparts.com/techarticles/M...auge_repair.htm I just did it two days ago and it worked very well. Take your time and follow it step by step. Don't bother trying to glue the pot metal gear on...use vice grips (just tightening them a little at a time) on the hole of to pot metal gear to deform it until is fits snugly onto the shaft. You can test it's operation with a small jewlers screwdriver in the drive shaft gage. |
| ClayPerrine |
Jul 27 2009, 07:28 AM
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,542 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille
First off.. if the car was ever air conditioned, the cable will have been removed from the dash and allowed to dangle. With AC, the cable is obstructed in the original location.
Second, the gear could be broken, you won't know until you get in there and look. But it is not likely. Third, NEVER reset the trip odometer while you are moving. This is what causes the gear to strip in the odometer. The reset locks the numbers and that causes the gear to slip on the shaft, breaking the odometer. |
| lotus_65 |
Aug 31 2009, 10:01 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,609 Joined: 21-March 05 From: minneapolis, mn Member No.: 3,795 Region Association: Northstar Region |
The gear usually does not need replacement. The fix is to disassemble the head and knurl the shaft where the gear is so the shaft turns with the gear as it did when new. The trip counter should work once the odometer is fixed. The reset is a knob not a button. Should be under the dash to the right of the steering column and the knob will only turn one way. i'm doing this (knurling the shaft) tonight, as opposed to the method on the pelican site. how did this happen? QUOTE NEVER reset the trip odometer while you are moving. (IMG:style_emoticons/default/stromberg.gif) shit |
| Betty |
Aug 31 2009, 10:11 PM
Driver ![]() ![]() ![]() Group: Members Posts: 521 Joined: 10-December 04 From: Hurst, TX Member No.: 3,255 Region Association: South East States
"NEVER reset the trip odometer while you are moving. This is what causes the gear to strip in the odometer. The reset locks the numbers and that causes the gear to slip on the shaft, breaking the odometer."
He speaks the truth... voice of stupid experience here.... (IMG:style_emoticons/default/headbang.gif) Really sucks if you're driving in a rally. There's no resetting of the trip odometer unless you're at a stop sign or traffic light. |
| 70Sixter |
Sep 1 2009, 03:44 PM
Member ![]() ![]() Group: Members Posts: 422 Joined: 3-August 04 From: Surf City, NC Member No.: 2,444 Region Association: South East States |
"NEVER reset the trip odometer while you are moving. This is what causes the gear to strip in the odometer. The reset locks the numbers and that causes the gear to slip on the shaft, breaking the odometer." He speaks the truth... voice of stupid experience here.... (IMG:style_emoticons/default/headbang.gif) One more stoopid voice of experience here. |
| VaccaRabite |
Oct 3 2009, 07:53 AM
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,845 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region
Sounds like the only stoopid were the engineers that designed the system to fail with intended usage.
Zach |
| kenshapiro2002 |
Oct 3 2009, 09:34 AM
Lo-Fi Version | Time is now: 17th April 2026 - 10:36 PM |
