gas pedal woes, very stiff |
jt914-6 |
Jul 28 2009, 08:02 PM
Driving & working on teeners 41 years Group: Members Posts: 1,786 Joined: 3-May 08 From: Bryant, Arkansas Member No.: 9,003 Region Association: South East States |
Check all your pedal assm. bushings. If they are plastic, replace them all with the bronze type. If you already have the bronze ones, clean the pedal assm. as well as you can. On the side to side to movement, remove cotter pin and use a washer/s to take slack out.
nycchef |
Jul 28 2009, 08:54 PM
mechanical moron Group: Members Posts: 952 Joined: 28-November 05 From: new york city n.y. Member No.: 5,202 Region Association: None |
Check all your pedal assm. bushings. If they are plastic, replace them all with the bronze type. If you already have the bronze ones, clean the pedal assm. as well as you can. On the side to side to movement, remove cotter pin and use a washer/s to take slack out. will do, a wise man(rtowle) once told me to balance the carbs use the idle adjust screw, the one that holds the throttle plate. which screw is that ? enclosing a weber link for clarity. http://www.webercarbsdirect.com/v/vspfiles...ics/40IDF70.pdf |
jt914-6 |
Jul 28 2009, 09:07 PM
That would be #26....
Lo-Fi Version | Time is now: 1st June 2024 - 12:33 PM |
