can you gas weld stainless steel? |
rfuerst911sc |
Jul 27 2009, 05:12 PM
Advanced Member Group: Members Posts: 2,158 Joined: 4-May 06 From: Dahlonega , Georgia Member No.: 5,980 Region Association: South East States |
I have a muffler for my /6 conversion that was shipped with the tailpipes not attached. This was done to allow custom fitment. Can this material be welded using oxy acetylene ? The muffler and tailpipes are 321SS. Any tips are appreciated.
underthetire |
Jul 27 2009, 05:14 PM
Maybe but you will turn it all kinds of cool purple doing it.
tat2dphreak |
Jul 27 2009, 05:30 PM
mig weld it with SS wire.
underthetire |
Jul 27 2009, 05:38 PM
Tig would be better.
rick 918-S |
Jul 27 2009, 06:14 PM
Hey nice rack! -Celette Group: Members Posts: 20,460 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
Yes, go to your local welding supply store and ask what filler rod they reccomend. Use a stainless wire brush on a drill to remove the discoloration. Stainless pulls heat like crazy.
rfuerst911sc |
Jul 27 2009, 07:06 PM
After some internet research I've decided to hire this out. Thanks guys.
Mark Henry |
Jul 27 2009, 08:41 PM
Tack it up with MIG, then take it to someone with a TIG.
sean_v8_914 |
Jul 27 2009, 09:05 PM
you will require a spool gun($400 option) because your wire feed tube is contaminated. you will also need a different argon gas mix
geniusanthony |
Jul 27 2009, 10:00 PM
Its a brand new "Chrome-sicle" Group: Members Posts: 517 Joined: 12-December 05 From: Alexandria,VA Member No.: 5,266 Region Association: MidAtlantic Region |
It sounds like you have made your decision, but for future reference there is a SS arc rod you could use.
IronHillRestorations |
Jul 27 2009, 10:26 PM
You made the right choice. Stainless takes practice.
Mikey914 |
Jul 27 2009, 10:43 PM
The rubber man Group: Members Posts: 12,669 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Ask them to acid treat the weld. Heating the stainless frees up iron, the acid will react and dissolve it leaving you with the more rust resistant qualities of the stainless you desire.
http://www.aws.org/w/a/wj/2002/05/feature/index.html Any shop that deals with architectural stainless products (like railing) can do this. |
Mark Henry |
Jul 28 2009, 05:36 AM
Her's a company that sells the acid, and there's a good pic of with/without treatment, looks like a muffler. I don't know them, just googled it.
http://www.avestafinishing.com/pages/Page____3296.aspx |
rfuerst911sc |
Jul 28 2009, 04:31 PM
I called my mechanic today and asked if he knew anyone that can weld SS and he said he did. I described what was needed and he said no problem so it looks like I have this covered. Thanks everyone.
Lo-Fi Version | Time is now: 17th May 2024 - 04:07 PM |
