rfuerst911sc
Jul 27 2009, 05:12 PM
I have a muffler for my /6 conversion that was shipped with the tailpipes not attached. This was done to allow custom fitment. Can this material be welded using oxy acetylene ? The muffler and tailpipes are 321SS. Any tips are appreciated.
underthetire
Jul 27 2009, 05:14 PM
Maybe but you will turn it all kinds of cool purple doing it.
tat2dphreak
Jul 27 2009, 05:30 PM
mig weld it with SS wire.
underthetire
Jul 27 2009, 05:38 PM
Tig would be better.
rick 918-S
Jul 27 2009, 06:14 PM
Yes, go to your local welding supply store and ask what filler rod they reccomend. Use a stainless wire brush on a drill to remove the discoloration. Stainless pulls heat like crazy.
rfuerst911sc
Jul 27 2009, 07:06 PM
After some internet research I've decided to hire this out. Thanks guys.
Mark Henry
Jul 27 2009, 08:41 PM
Tack it up with MIG, then take it to someone with a TIG.
sean_v8_914
Jul 27 2009, 09:05 PM
you will require a spool gun($400 option) because your wire feed tube is contaminated. you will also need a different argon gas mix
geniusanthony
Jul 27 2009, 10:00 PM
It sounds like you have made your decision, but for future reference there is a SS arc rod you could use.
IronHillRestorations
Jul 27 2009, 10:26 PM
You made the right choice. Stainless takes practice.
Mikey914
Jul 27 2009, 10:43 PM
Ask them to acid treat the weld. Heating the stainless frees up iron, the acid will react and dissolve it leaving you with the more rust resistant qualities of the stainless you desire.
http://www.aws.org/w/a/wj/2002/05/feature/index.htmlAny shop that deals with architectural stainless products (like railing) can do this.
Mark Henry
Jul 28 2009, 05:36 AM
Her's a company that sells the acid, and there's a good pic of with/without treatment, looks like a muffler. I don't know them, just googled it.
http://www.avestafinishing.com/pages/Page____3296.aspx
rfuerst911sc
Jul 28 2009, 04:31 PM
I called my mechanic today and asked if he knew anyone that can weld SS and he said he did. I described what was needed and he said no problem so it looks like I have this covered. Thanks everyone.
