Ting ting engine noise on a 2.2 /6, WTF is that! and timing question |
Mark Henry |
Jul 28 2009, 12:51 PM
Left hand side, more towards the front rocker area. severial times now, warm, but not hot (4min run @ 80mph).
Sounds like an engine cooling, ting ting, but loud enough to hear over an idling engine, a few times /min. My buddies car, it's got a flat spot and it's backfiring a bit. I'm looking for an exhaust leak, going to adjust the carbs, plugs and timing. Timing? #1 is right front and there should be a mark bottom of fan right? Stock 2.2, solexes, with a fireball ignition. What do you guys want for advance? same as a T4? been a while... Thanks |
Justinp71 |
Jul 28 2009, 01:04 PM
Senior Member Group: Members Posts: 1,583 Joined: 11-October 04 From: Sacramento, CA Member No.: 2,922 Region Association: None |
My buddies 911 sc had something similiar and it was a broke chain ramp in the timing chain housing. He replaced all the ramps, rebuilt the tensioners and added the safety collars on them.
It also seems to me that the fans commonly make noises on the 6's, I think its when the alternator bearings start getting sloppy... Let us know what you find. On my car I think I run 32 deg total timing, its a carbed 3.0... |
Jul 28 2009, 01:06 PM
Custom Member Group: Members Posts: 24,585 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Yup, I would pull the covers and look at the static timing of the cams...and the tensioners.
If done now, it may be safer. But, this comes from a guy who just did a 924S timing belt/head repair....so maybe I am a wee bit sensitive to the subject. Rich |
Cap'n Krusty |
Jul 28 2009, 01:23 PM
Left hand side, more towards the front rocker area. severial times now, warm, but not hot (4min run @ 80mph). Sounds like an engine cooling, ting ting, but loud enough to hear over an idling engine, a few times /min. My buddies car, it's got a flat spot and it's backfiring a bit. I'm looking for an exhaust leak, going to adjust the carbs, plugs and timing. Timing? #1 is right front and there should be a mark bottom of fan right? Stock 2.2, solexes, with a fireball ignition. What do you guys want for advance? same as a T4? been a while... Thanks Set it at 30 degrees BTDC at 6K RPM. There's a label on the fan strap. 2.2s had Zenith carbs. Solexes were replaced by Webers sometime in 1966, and they in turn were replaced by Zeniths in 1970. |
6freak |
Jul 28 2009, 01:32 PM
[quote name=
Timing? #1 is right front and there should be a mark bottom of fan right? I thought it was right side back plug "Timeing mark is on the flywheel".small rectangle hole between (of course the motor and tranny).If i remember correctly if its at TDC you should see a Z-1 mark ..Make sure the rotor is pointing at that plug...I could be all messed up so one of the pros will chim in soon.Hope im right my memory about as short as my penis (IMG:style_emoticons/default/lol-2.gif) |
Mark Henry |
Jul 28 2009, 01:57 PM
to me right front is... standing at back, right side, plug closest to the front of car
Mark Henry |
Jul 28 2009, 02:10 PM
Cap't you're right (I was guessing, but knew not weber) Thanks
Rich I hear ya, did the timing belt on my Passat 1.8T 3 weeks ago, 3 yrs overdue, belt was just a floppin and tensioner seized. Sorry you didn't have my luck bud...I dodged the bullet, I bought a lotto ticket that day! |
Cap'n Krusty |
Jul 28 2009, 03:31 PM
[quote name= Timing? #1 is right front and there should be a mark bottom of fan right? I thought it was right side back plug "Timeing mark is on the flywheel".small rectangle hole between (of course the motor and tranny).If i remember correctly if its at TDC you should see a Z-1 mark ..Make sure the rotor is pointing at that plug...I could be all messed up so one of the pros will chim in soon.Hope im right my memory about as short as my penis (IMG:style_emoticons/default/lol-2.gif) CAUTION! If the car has a 2.2, 2.4, or 2.7 crank, the TDC mark on the flywheel will most likely be wrong! While the bolt pattern is the same, the clocking is different. You MUST confirm the TDC mark, as well as the timing marks with those on the pulley! The Cap'n |
Mark Henry |
Jul 28 2009, 04:09 PM
Do I use chop sticks?
Should have said this, it's a 911t and I think the original engine. He had 1-1/2 quarts too much oil, looks like it's been leaking oil from the nose and sucking it through the fan. What a mess, I think i'll power wash it and try again tomorrow. Anything to watch for when washing (besides the intake and electrics left side and I guess the sump right, I'll cover/bag that) Never washed a 911 engine before. Rocked the the engine back and forth, no noise from the chains, may check them anyways. Alternator/fan feels tight. |
Mark Henry |
Jul 28 2009, 04:21 PM
Least I figured out where #1 is, LOL sticker was there, covered with masking tape.
Jul 28 2009, 05:31 PM
I would ask...or research...what is the chain tensioner?
I know that they do fail and upgrading to the later tensioner seems to be a popular upgrade....no idea. ting ting ting....think about it. You have the fan...OR you have pistons/valve contact.... OR Chain... thems the moving parts that could go ting ting ting... Rich |
6freak |
Jul 29 2009, 09:28 AM
Mark Henry |
Jul 29 2009, 10:30 AM
Closest to the dizzy, ass backwards from a T1 and T4. Probably the designer was a dyslexic from VW.
Figured out ting ting, pretty sure it's detonation... should of figured that, rhymes with ping. Now timing marks...having a bit of trouble figuring out this pulley Found this thread http://forums.pelicanparts.com/showthread....667#post4731667 but the marks don't match what I have. Can't find the VIN plate (trunk?) but the insurance slip says it's a '71. The pic is of the pulley, timing was closest to these two marks that are 5mm apart, there is no Z1 mark. I've moved (retarded) the "at idle" speed close to the left (of the two 5mm apart marks) mark. I don't see a mark around 30*..... Anyone know a better link on pulley timing marks? I've done a rough sync and things are much better, crisper and the backfire is gone. Still popping through one carb barrel if I blip it a few times. But I'd like to figure out the timing before I rev it up. Attached thumbnail(s) |
Mark Henry |
Jul 29 2009, 12:00 PM
From the bird board:
QUOTE The odd part about your picture is where the hole in the pully is in relation to the marks you are showing on the pulley. If you look at the pictures up above the hole in the pulley face is directly below the Z1 mark whereas on your picture it is well to the left of the mark you have the engine lined up on. All of these type of pulleys that I have seen have the holes in the face of the pulley line up with the Z1 mark. Since I'm at work at the moment I can't check on this now but IIRC, the woodruff key that locates the pulley on the crankshaft also lines up with the Z1 mark on the pulley. I can check on this later if needed. So in the pic it's sitting at 30*? far left is TDC and far right 35*? Far left does have a line on the face, the others don't. If so I'd say the advance isn't working right and that actually might have saved the engine, as it was way over advanced. Looks like it's only advancing a little over 5*. |
rudedude |
Jul 29 2009, 12:26 PM
Senior Member Group: Members Posts: 510 Joined: 1-January 05 From: minneapolis, mn Member No.: 3,387 Region Association: Upper MidWest |
You are right!
The left mark is tdc and the right are 30 and 35 degrees. Should also be marks at 120 degrees from tdc with line on face only like tdc for valve timing, no cut on edge of pulley. Jule |
Mark Henry |
Jul 29 2009, 01:14 PM
I think the dizzy is pooched, or needs work. The weight is flopping but both springs are on. There is a thin black plate between the weight assembly and the bottom and it looks broken in 3-4 places, I can push them around with a screwdriver tip.
Dizzy # 0 231 159 002 is that correct for this engine?...and I guess I'm looking for one. |
PeeGreen 914 |
Jul 29 2009, 01:22 PM
Just when you think you're done...wait, there is more..lol Group: Members Posts: 10,219 Joined: 21-September 06 From: Seattle, WA... actually Everett Member No.: 6,884 Region Association: Pacific Northwest |
Least I figured out where #1 is, LOL sticker was there, covered with masking tape. So where you right the first time .........Back of the car ,right side ,front ???...or was it back of the car right side back What the hell are you talking about Mike? #1 is the closest to the passenger, for those that didn't know. Mike, the engine Mark is working on isn't like yours. The markings may be different just as the Capt'n said. 914-6s are different than 911 engines and you can't assume the people who did the conversion did everything to read the same until you confirm it yourself. |
Mark Henry |
Jul 29 2009, 01:32 PM
Guys... It's not a conversion, it's my mistake, I wasn't clear in the beginning of the thread.
It's a 911 1971 2.2t (i believe 2.2) the tag I found is, from rear of car, beside the dizzy is #1 /2/3 left side, 4/5/6 right side of a 911 Or is that the firing order ????...man where is #1 (sticker is in bad shape) I'm a total dyslectic you need to be clear.... |
rudedude |
Jul 29 2009, 01:58 PM
#1 by the distributor, next are 2 and 3, other side opposite 1 is 4 then 5 and 6
Firing1-6-2-4-3-5 |
PeeGreen 914 |
Jul 29 2009, 02:02 PM
(IMG:style_emoticons/default/beerchug.gif) Cool. Which makes looking at the flywheel very difficult (IMG:style_emoticons/default/laugh.gif) . So on 911s they have a sticker that says #1? I always knew #1 was closest to the distributor but that was just how I was taught. I didn't have to find it on my own. That is the right order but not the firing order.
rudedude has the right firing order. |
Lo-Fi Version | Time is now: 1st June 2024 - 10:29 AM |
