Tie down/Tow Rear Bumper Connection Late Model, Anyone used it or have the eye-bolt? |
tyler |
Jul 28 2009, 02:11 PM
Member Group: Members Posts: 335 Joined: 24-September 03 From: southern california Member No.: 1,192 |
I'm not sure of the exact purpose of the threaded hole under the cap on the rear bumper, drivers side. Since it's not very big, I would guess it was for a shipping tie down and not a tow hook.
I'm interested because if I ever need to get hauled up on a flatbed, my front air dam is too low to run a cable under and the rear doesn't have much to hook to that wouldn't screw up the valance. So I'd like to be able to use this threaded hole to connect a tow hook to from a flatbed. It's pretty small so I'm trying to find out if anyone has used it and if it would work. If so, are OEM eyebolts available or does someone know the thread size, offhand. Thanks, |
Mark Henry |
Jul 28 2009, 02:14 PM
It is a tow hook but you can only pull straight back on it and it's not for getting stuck cars out of the mud.
Yes you should have a ring. Never do what your thinking of doing. Many peeps make tow/flatbed hook rings that they bolt to the lower shock bolt. |
SLITS |
Jul 28 2009, 02:40 PM
I used it to tow another 914 that wouldn't start ... it'll work
Lo-Fi Version | Time is now: 17th May 2024 - 03:07 PM |
