914 factory 6 Dist. Caps |
xsurfer |
Jul 29 2009, 10:44 PM
Member Group: Members Posts: 279 Joined: 4-April 06 From: La Canada, CA Member No.: 5,818 |
I'm the proud owner of an orig six with 87K orig miles. I have just seen a distributor cap on e bay stating that it is the short MARELLI cap of the two posible caps. It stated a part number. Can someone comment on the two caps. They are few and far between. I may have a new short cap and not know it! Obviously I'm still learning this car.
Thanks for the great forum and knowledge from it. Gene Selger |
brp986s |
Jul 29 2009, 11:29 PM
Member Group: Members Posts: 434 Joined: 27-September 07 From: los angeles Member No.: 8,167 |
If your distributor is Bosch you have a short cap and caps/rotors for it should be available. If you have a marelli, the cap is taller. Marelli parts are rare or gone.
I'm the proud owner of an orig six with 87K orig miles. I have just seen a distributor cap on e bay stating that it is the short cap of the two posible caps. It stated a part number. Can someone comment on the two caps. They are few and far between. I may have a new short cap and not know it! Obviously I'm still learning this car. Thanks for the great forum and knowledge from it. Gene Selger |
xsurfer |
Jul 30 2009, 03:12 AM
My apologies, it is a Marelli Short Cap.
If your distributor is Bosch you have a short cap and caps/rotors for it should be available. If you have a marelli, the cap is taller. Marelli parts are rare or gone. I'm the proud owner of an orig six with 87K orig miles. I have just seen a distributor cap on e bay stating that it is the short cap of the two posible caps. It stated a part number. Can someone comment on the two caps. They are few and far between. I may have a new short cap and not know it! Obviously I'm still learning this car. Thanks for the great forum and knowledge from it. Gene Selger |
Van914 |
Jul 30 2009, 04:35 AM
Van914 Group: Members Posts: 698 Joined: 5-January 03 From: Cincinnati, Ohio Member No.: 90 Region Association: Upper MidWest |
It won't fit.
dr914@autoatlanta.com |
Jul 30 2009, 09:34 AM
914 Guru Group: Members Posts: 7,840 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
we are in the process of remaking the marelli distributor caps and rotor and actually need another sample preferably new as a sample. Any one out there have one? All 1970 914-6 models were equipped with Marelli distributors (the tall one) and the 71 models bosch (the short one)
mskala |
Jul 30 2009, 10:55 AM
we are in the process of remaking the marelli distributor caps and rotor and actually need another sample preferably new as a sample. Any one out there have one? All 1970 914-6 models were equipped with Marelli distributors (the tall one) and the 71 models bosch (the short one) I will check tonight, I think one of mine is new in box. |
xsurfer |
Jul 30 2009, 06:16 PM
we are in the process of remaking the marelli distributor caps and rotor and actually need another sample preferably new as a sample. Any one out there have one? All 1970 914-6 models were equipped with Marelli distributors (the tall one) and the 71 models bosch (the short one) I will check tonight, I think one of mine is new in box. My 71 has original records with no mention of changing a distributor, it still has a Marelli. Does anyone know about two sizes of marelli caps? Is the height of the cap only in the wire recepticles. I'll try to dig up a part number. |
mskala |
Jul 30 2009, 07:25 PM
we are in the process of remaking the marelli distributor caps and rotor and actually need another sample preferably new as a sample. Any one out there have one? All 1970 914-6 models were equipped with Marelli distributors (the tall one) and the 71 models bosch (the short one) I will check tonight, I think one of mine is new in box. Yep, I have an unused one if you need to take measurements |
Pat Garvey |
Jul 30 2009, 08:20 PM
If your distributor is Bosch you have a short cap and caps/rotors for it should be available. If you have a marelli, the cap is taller. Marelli parts are rare or gone. I'm the proud owner of an orig six with 87K orig miles. I have just seen a distributor cap on e bay stating that it is the short cap of the two posible caps. It stated a part number. Can someone comment on the two caps. They are few and far between. I may have a new short cap and not know it! Obviously I'm still learning this car. Thanks for the great forum and knowledge from it. Gene Selger I've known of this problem for years, but never understood why the Factory made such a change. Any enlightenments? Pat |
smg914 |
Jul 30 2009, 09:59 PM
Sahara Beige Steve Group: Members Posts: 1,962 Joined: 22-February 04 From: Tampa, FL Member No.: 1,695 Region Association: None |
Lightweight_911 |
Jul 31 2009, 04:50 AM
Member Group: Members Posts: 71 Joined: 7-October 06 From: London, UK Member No.: 7,008 |
Here's a new 'short' Marelli cap - I have 2 of them (NOS).
I don't think they were used on the 914/6 (maybe possibly on the rare '72 models ?). (IMG:http://farm3.static.flickr.com/2566/3774008999_54f77eb26c.jpg) (IMG:http://farm4.static.flickr.com/3475/3774815112_2328dd330d.jpg) (IMG:http://farm3.static.flickr.com/2637/3774803678_e75a65053c.jpg) (IMG:http://farm3.static.flickr.com/2649/3774803820_54f450c248.jpg) |
xsurfer |
Jul 31 2009, 09:27 AM
If your distributor is Bosch you have a short cap and caps/rotors for it should be available. If you have a marelli, the cap is taller. Marelli parts are rare or gone. I'm the proud owner of an orig six with 87K orig miles. I have just seen a distributor cap on e bay stating that it is the short cap of the two posible caps. It stated a part number. Can someone comment on the two caps. They are few and far between. I may have a new short cap and not know it! Obviously I'm still learning this car. Thanks for the great forum and knowledge from it. Gene Selger I've known of this problem for years, but never understood why the Factory made such a change. Any enlightenments? Pat I think, I have all of two years experience, the marelli was a lighter distributor. Gene |
smg914 |
Jul 31 2009, 09:41 AM
Back in the day all the caps had a 901 part number. The design of the Marelli distributor used in the early 911's and 914-6's required the taller distributor cap. The Bosch distributor used during this same time period was a different design which required a shorter cap. My guess is that at some point in time Marelli made a shorter replacement cap that would fit the Bosch distributor and possibly some of their later design distributors. I don't see any way that the short Marelli cap could ever be used on the original stock Marelli 914-6 distributor.
Project 6 |
Sep 13 2009, 05:05 AM
large member Group: Members Posts: 359 Joined: 30-December 02 From: Utah Member No.: 51 Region Association: None |
Convert to Bosch and live with the CW BS when you go to shows. Anyone still running a Marrelli has too much money or never drives the thing.
Jasfsmith |
Sep 14 2009, 08:17 AM
Senior Member Group: Members Posts: 556 Joined: 4-October 04 From: Bangor, ME Member No.: 2,882 Region Association: North East States |
Convert to Bosch and live with the CW BS when you go to shows. Anyone still running a Marrelli has too much money or never drives the thing. Your wrong on both accounts. I've got little money and drive a lot. Marelli parts can still be had. You just need to be patient and buy when they pop up. I've got a supply that will likely out last the distributor. Then again I've got a ample supply of Marelli distributors. Not sure why... <sigh> |
Lo-Fi Version | Time is now: 8th May 2024 - 04:46 PM |
