offering several new machined items, if anyone is interested, headlight doesn't sit correctly or shakes? |
dlestep |
Aug 1 2009, 11:04 PM
I am smilin'... Group: Members Posts: 890 Joined: 15-January 08 From: Sunrise Florida Member No.: 8,573 Region Association: South East States |
...new at offering anything on this website.
But as I go through my restoration, I have had to have several things remanufactured, machined, or re-fabricated when they are no longer available. These particular items are not available from any sources that I can find. 1. bearing bracket bushings, (4), used on 914 750 165 10 and 914 750 271 10. 2. 914 750 189 10, bearing sleeve, (4), used on headlight motor push rod. 3. pivot pin, (2), used on push rod, 914 750 185 11, left and right side. The material used on items 1 & 2 above is a black acetal resin (Delrin), the original was white. The material used on item 3 is bronze. I increased the root diameter of the threaded portion using a .250-28UNF-3A thread instead of a M6 Thread. I also increased the diameter of the thread relief just before the bearing surface that interfaces with the headlight mounting assembly. (When the M6 nut works it way loose, the part fails forward of the bearing surface on the narrow root diameter of the thread, then the headlight assembly imperceptively flops, but most notible, the headlight doesn't sit flush with the curve of the front trunk lid). The vendor cost of item 1, (4) is $ 8.00 a piece, 4*8=$ 32.00. The vendor cost of item 2, (4) is $ 8.00 a piece, 4*8=$ 32.00. The vendor cost of item 3, (2) is $20.00 a piece, 2*20.00= $ 40.00. (considering the size and weight, or lack there of, shipping is included). This is just what I paid for a one off deal. I'm sure the costs will drop with quantities. Anyone can leave me a personal msg or reply to this thread. Dave Estep, (dlestep). |
zymurgist |
Aug 2 2009, 09:08 AM
"Ace" Mechanic Group: Members Posts: 7,411 Joined: 9-June 05 From: Hagerstown, MD Member No.: 4,238 Region Association: None |
Neat stuff. Babydoll has one headlight that I was unable to ever get to align correctly. I don't know whether this was due to wear surfaces wearing out, or accident damage.
dlestep |
Aug 2 2009, 11:17 AM
Neat stuff. Babydoll has one headlight that I was unable to ever get to align correctly. I don't know whether this was due to wear surfaces wearing out, or accident damage. ...remove the top cover (screws on the side) and watch the motion when some else activates the switch. In the up position, see if there is any motion by moving the push rod. check the pivot pin. see if the small M6 nut is loose. if it is, remove the nut and check the threads of the pivot pin. if it has been operating with the loose nut, then there may be wear on the base of the thread and thats where it may fail. Also check the initial alignment of the bearing brackets. One side is slotted. the outboard bearing plates are in the fender well. loosen the screws and see if you can place the assembly in the correct position. that may only be the problem, however; we are talking 30 plus years of wear on the original bushings from the electrical motors out to the headlight assemblies. If your headlights jiggle over bumps and what not, these may help that. |
JazonJJordan |
Aug 4 2009, 10:37 AM
Member Group: Members Posts: 340 Joined: 6-June 09 From: Atlanta-Augusta, Georgia area Member No.: 10,446 Region Association: South East States |
(IMG:style_emoticons/default/smash.gif) Cool work Dave, I don't think this has been well covered before-Thanks! (IMG:style_emoticons/default/shades.gif)
dlestep |
Aug 8 2009, 12:43 AM
I was surprised at the total lack of interest on this. (IMG:style_emoticons/default/idea.gif)
I was inspired by the few 914s locally and alot of the photographs of 914s with at least one light out of wack when closed. Not from adjustment but from worn bushings. A couple of 914s driving behind me at night had jittering headlights, not from a stiff suspension, but from a loose assembly. I have also noticed that it is usually just one light, not both. ...The costs for items that I have listed are for my 914, and at a one off deal, Not the costs for a group of people that have interest. I was sure that I wasn't the only one with a 35 year old car with worn bushings. Besides, I am not bumping these costs with profit for myself. The costs would go totally to the machinist. I was attempting to provide components that I haven't seen on any website, parts house or otherwise. The headlight pivot bushings are available only when you purchase the headlight assembly. I have yet to see the push rod bushings available anywhere, and the pivot pins, don't appear anywhere as well. (with your headlights up, if you can move the assembly with your finger, replacing the bushings on the both the headlight support tube and the push rod will remove any play in that assembly. The only other thing that will cause the slight movement would be the at the electric motor drive pin, <rear position on the push rod>. That component can also wear and allow movement as well). So......The question was if anyone is interested, I will talk with the machinist on a group deal. Even if there is only a few interested, I can get them for you. Again this is not for my profit, just providing a source of NLA parts for 914 owners on this website. Dave (IMG:style_emoticons/default/type.gif) |
Todd Enlund |
Aug 8 2009, 02:30 AM
Resident Photoshop Guru Group: Members Posts: 3,251 Joined: 24-August 07 From: Laurelhurst (Portland), Oregon Member No.: 8,032 Region Association: Pacific Northwest |
Dave, post it in the garage.
Gint |
Aug 9 2009, 09:09 AM
Mike Ginter Group: Admin Posts: 16,070 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
I'm interested in these parts for my /6 restoration.
The member/vendor forum is for members that are vendors that intend to produce and sell parts, presumably on an ongoing basis. It really isn't read or responded to on a daily basis by the members at large like the garage. If you were to produce these parts for sale on a regular basis, then an announcement in the garage that your providing this product with a link to a thread in member/vendor forum would be the thing to do. If you want to put together a group buy type of situation for these parts, that's different and this thread certainly could go to the garage. What do you want to do? |
dlestep |
Aug 9 2009, 09:18 AM
I'm interested in these parts for my /6 restoration. The member/vendor forum is for members that are vendors that intend to produce and sell parts, presumably on an ongoing basis. It really isn't read or responded to on a daily basis by the members at large like the garage. If you were to produce these parts for sale on a regular basis, then an announcement in the garage that your providing this product with a link to a thread in member/vendor forum would be the thing to do. If you want to put together a group buy type of situation for these parts, that's different and this thread certainly could go to the garage. What do you want to do? ...please move this thread to the garage. My whole intent was to provide these to anyone on the website who needs them. The machinist is who I use from work. He's really good at what he does. I can talk to him about quantities and schedule. I guess that I will be helping with the addresses to ship to. I just saw a need and I'm trying to meet it. thanks for your help in this. Dave |
stepuptotheMike |
Aug 9 2009, 09:52 AM
medium pimpin Group: Members Posts: 565 Joined: 4-September 06 From: Charlotte, NC Member No.: 6,769 Region Association: South East States |
I would be interested in at least parts 1 & 2.
Mike |
dlestep |
Aug 9 2009, 10:19 AM
...so far, I have started a chart on who's interested
zymuquist_________is reviewing need Gint______________is interested stepuptothemike____is interested in items 1 and 2. I have also talked a little bit with the machinist and spoke of quantities and possible schedule. It will be a little easier if I have a list to work by, but if the run up is slow on the website, I could initiate a limited short run of quantities. I will be talking with the machinist Monday on the short run. That would make the turnaround shorter for the initial purchases. Just as a point of interest, I will be checking all components for intermating part fit against real parts as acceptance/rejection prior to shipping. Dave (IMG:style_emoticons/default/type.gif) |
jmill |
Aug 9 2009, 02:27 PM
I seriously appreciate you going the extra mile on this one and offering them up for a group buy. Right now I'm far from rebuilding the headlights. Hopefully there will be a time in the not so distant future when I can improve the minor items. Unfortunately, getting the front passenger fender welded back on and installing flares is at the top of my list. Don't get frustrated by the lack of interest. The reason I come here is guys like you that help out the group.
John (IMG:style_emoticons/default/pray.gif) |
scottb |
Aug 9 2009, 02:33 PM
who wants a PEZ?! Group: Members Posts: 1,993 Joined: 27-December 02 From: south-(not north)-wick, MA Member No.: 32 Region Association: North East States |
my car is in pretty good shape so i need to find a way to spend $$$ on it and a reason to tear it apart. this fits the bill. put me down for the whole lot.... cheers, scott |
dlestep |
Aug 9 2009, 06:37 PM
my car is in pretty good shape so i need to find a way to spend $$$ on it and a reason to tear it apart. this fits the bill. put me down for the whole lot.... cheers, scott ...gotcha on the list for headlight bushings, push rod bushings and pivot pin. Tonight, I will be updating the photo of the full assembly. It will be more straight forward and easier to discern. thanks, Dave |
dlestep |
Aug 9 2009, 09:32 PM
updated pic of components....
The vendor cost of item 1, (4) is $ 8.00 a piece, 4*8=$ 32.00. The vendor cost of item 2, (4) is $ 8.00 a piece, 4*8=$ 32.00. The vendor cost of item 3, (2) is $20.00 a piece, 2*20.00= $ 40.00. (considering the size and weight, or lack there of, shipping is included). Anyone can leave me a personal msg or reply to this thread. Dave Estep, (dlestep). (IMG:style_emoticons/default/type.gif) |
McMark |
Aug 9 2009, 09:37 PM
I'm interested in two sets.
dlestep |
...OK, WHO SAT ON MY PICTURE ? |
dlestep |
Aug 9 2009, 09:39 PM
dlestep |
Aug 9 2009, 10:44 PM
dlestep |
Aug 11 2009, 06:36 PM
...the machinist will be in my office tomorrow at 1100 hrs. We will be going over tolerances and kit definition and quantities. I performed a tolerance study on each of the components and found two dimensional changes on the bushings.
The motor side bushing of the push rod needs an additional .00152 split on the ID and OD of the pivot pin bushing on the push rod needs an additional .00325., at least on my push rods. All of the components fit well, but the have 1 degree of play that I want to remove. With the rocking arc movement of the headlight stepper motor, I would like to limit the motion to one plane. I would like some cross data, if anyone has headlight push rods that are out of the car, I would appreciate 5 place decimal reads on the ID, so hopefully, a few reads from someone with a caliper would be good. (thanks in advance). I will be adding washers and .250-28UNF-3B Nylon Insert, Hex Nuts to the kit, for the pivot pin install, so everyone goes out clean. If anyone else wants to jump on this, I am arranging a short run of 10 sets. I will let everyone know, on the list, when they are ready. Now I have to arrange a paypal account or something and get everyone's mailing address. Dave (IMG:style_emoticons/default/type.gif) |
McMark |
Aug 12 2009, 12:05 AM
Two cars.
Lo-Fi Version | Time is now: 10th May 2024 - 04:27 AM |
