PORSCHE lettering on engine lid |
RiqueMar |
Aug 5 2009, 04:07 PM
Enrique Allen Mar Group: Members Posts: 2,169 Joined: 28-August 08 From: San Diego, CA Member No.: 9,478 Region Association: Southern California |
I'm having some trouble getting the gold lettering off the grille, specifically with the rubber grommets that hook to the backside.
Any suggestions? WD40? Heat? |
jt914-6 |
Aug 5 2009, 04:14 PM
Driving & working on teeners 41 years Group: Members Posts: 1,786 Joined: 3-May 08 From: Bryant, Arkansas Member No.: 9,003 Region Association: South East States |
You'll probably have to buy new keepers after you remove the old ones. I'm sure, depending on year, that the letters may be plastic......so, heat is out. Either way, I wouldn't use heat. The keepers are round metal with a hole in the center wrapped by rubber. The best way I have found is to get some good needle nose and try to "unscrew" them. Be careful though, the studs they go on could break. Take your time......
dr914@autoatlanta.com |
Aug 5 2009, 04:22 PM
914 Guru Group: Members Posts: 7,864 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
I'm having some trouble getting the gold lettering off the grille, specifically with the rubber grommets that hook to the backside. Any suggestions? WD40? Heat? We squeeze the grommets with pliers which opens the hole allows the grommets to come off very easily without damaging the lettering studs and destroys the grommets!!! New factory ones are readily available |
JoeSharp |
Aug 5 2009, 05:27 PM
In Irvine, Ca. May 15-18 Group: Members Posts: 3,947 Joined: 9-July 03 From: DeLand, Florida Member No.: 898 Region Association: South East States |
I use a set of small vice grips, set them to crush the washer and it comes right off. Ace hardware has a spring clip washer for $.03 that can replace them if your not a C/W.
PanelBilly |
Aug 5 2009, 05:39 PM
914 Guru Group: Members Posts: 5,807 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
USE A CHAINSAW
I need time to catch up and I figure if he takes a few steps backward, that will give me more time. |
RiqueMar |
Aug 5 2009, 06:48 PM
USE A CHAINSAW I need time to catch up and I figure if he takes a few steps backward, that will give me more time. No way Billy, we all know that by nature Orange is faster than Blue even in the build stages. It's science. BTW I still need to write you a check, but don't know where to send it. |
Rand |
Aug 5 2009, 07:54 PM
USE A CHAINSAW I need time to catch up and I figure if he takes a few steps backward, that will give me more time. (IMG:style_emoticons/default/lol-2.gif) Rique, you already got your answer, just confirming another vote to pinch them with pliers. They slip right off if you relax their grip. |
Lo-Fi Version | Time is now: 18th May 2024 - 02:17 AM |
