Linkage question |
Linkage question |
schreiber |
Aug 7 2009, 08:58 AM
Member Group: Members Posts: 137 Joined: 26-June 07 From: Huntsville, AL Member No.: 7,843 Region Association: South East States |
Got this linkage with the 40IDf's. Who else uses this type of linkage? Is it super effective? Anyone have pictures?
SGB |
Aug 7 2009, 09:21 AM
Heya Jake-
I think that type of linkage is better than the cross-bar setup I have. Are you gonna be working on those carbs this weekend? I'll PM my phone number. Call if you want assistance, misdirection, or annoyance. (IMG:style_emoticons/default/smile.gif) |
schreiber |
Aug 7 2009, 12:40 PM
Thanks Scott - I'll be in Montgomery this weekend, otherwise I'd love the assistance, misdirection, or annoyance.
(IMG:style_emoticons/default/biggrin.gif) Really though, I would like your input soon as I'll have all my parts together for the carb swap sometime next week. I'll be in touch. |
sean_v8_914 |
Aug 7 2009, 01:02 PM
I like that type. raby likes it also
schreiber |
Aug 14 2009, 12:40 PM
if anybody has diagrams or photos of how this sucker goes in, i would appreciate
7275914911 |
Aug 14 2009, 01:20 PM
Hummmm!!! Group: Members Posts: 756 Joined: 7-May 08 From: Mid-South Member No.: 9,028 Region Association: South East States |
if anybody has diagrams or photos of how this sucker goes in, i would appreciate I will try and get a pic up of mine....I have modified mine a little with the CSP crank on top of the base you have. I had no problems with what you have got tho. worked with out a hitch. The carriage type bolt is a case bolt. The middle case bolt in my instance to be exact. My carbs pull from opposite sides. If your carbs pull from same side I would use the rear case bolt to attach the base. From there it is pretty staight forward for the linkage. You will have to "rig up" a throttle cable bracket. I used angle iron and bolted down to Dizzy mounting bolt. Other's have fabricated a better approach in my opin. There is a good thread recently on carb setup with quite a few pics... Good Luck Ken |
schreiber |
Aug 14 2009, 09:28 PM
QUOTE There is a good thread recently on carb setup with quite a few pics... Show me your dual carburetors setup yeah, if that's the thread you're referring to, i started that one... (IMG:style_emoticons/default/smile.gif) i still haven't seen a detailed photo of anybody with the same style linkage i have. i'm sure i'll figure it out with time. i made some progress tonight, at least now the carbs and manifolds are in place. |
schreiber |
Aug 16 2009, 09:59 PM
Also, anyone have suggestions on who sells a good throttle cable bracket?
Gint |
Aug 17 2009, 07:51 AM
Mike Ginter Group: Admin Posts: 16,075 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
Good throttle cable brackets for 914 dual carb setups are usually made and not bought.
jaxdream |
Aug 17 2009, 09:42 AM
Senior Member Group: Members Posts: 974 Joined: 8-July 08 From: North Central Tennessee Member No.: 9,270 Region Association: South East States |
As I replied in your other thread , there is a fella that makes , his brand name -side winder- out of billet aluminium , that is a great setup . Yours could work good with some tinkering. VW used this type setup on 67 T3 dual carbs, worked very well.
Jaxdream |
7275914911 |
Aug 18 2009, 01:44 PM
Lo-Fi Version | Time is now: 19th May 2024 - 12:20 PM |
