QUOTE(schreiber @ Aug 14 2009, 01:40 PM)
if anybody has diagrams or photos of how this sucker goes in, i would appreciate
I will try and get a pic up of mine....I have modified mine a little with the CSP crank on top of the base you have. I had no problems with what you have got tho. worked with out a hitch.
The carriage type bolt is a case bolt. The middle case bolt in my instance to be exact. My carbs pull from opposite sides. If your carbs pull from same side I would use the rear case bolt to attach the base. From there it is pretty staight forward for the linkage. You will have to "rig up" a throttle cable bracket. I used angle iron and bolted down to Dizzy mounting bolt. Other's have fabricated a better approach in my opin.
There is a good thread recently on carb setup with quite a few pics...
Good Luck
Ken
