How do I route the windshield waster hose, The lines that run from the steering column |
PanelBilly |
Aug 8 2009, 02:45 PM
914 Guru Group: Members Posts: 5,805 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
The two rubber hoses that come out of the back of the steering wheel. How do they find their way to the spare tire and the two squirters?
rstover |
Dec 16 2018, 05:23 PM
Member Group: Members Posts: 136 Joined: 15-November 11 From: Kerrville, TX Member No.: 13,785 Region Association: Southwest Region |
No guarantee this is correct, but this the way it was when I disassembled it. This is a 74 car. It may be hard to see the hoses, but there is two. One going and one coming. They routed behind the gauges and hooked up under the steering column to white connectors which were attached to the hoses going into the column control valve. I replaced the hoses going to the base of the column , but not the the ones inside column. I doubt that I will ever put water in washer or use it but replaced hoses.
The hole that the hoses are going thru are almost directly above the heater control wires which I think you can see. There was no grommet on the car for the water hoses , but suspect that there was at one time. I was able to find the black hose under the 356 parts. |
Lo-Fi Version | Time is now: 15th May 2024 - 12:29 PM |
