911 steering rack support, protective cover |
jt914-6 |
Aug 8 2009, 05:21 PM
Driving & working on teeners 41 years Group: Members Posts: 1,786 Joined: 3-May 08 From: Bryant, Arkansas Member No.: 9,003 Region Association: South East States |
Does anyone know if the 911 "protective cover" will work on a 914 that is using the I-beam aluminium support from a 911? I have a part number of 911 341 161 04. "74-89.
ArtechnikA |
Aug 8 2009, 05:43 PM
Does anyone know if the 911 "protective cover" will work on a 914 that is using the I-beam aluminium support from a 911? I have a part number of 911 341 161 04. "74-89. The 'auxillary support' is the same dimensionally, aluminum or steel, matters not if it's installed in a 914 or 911. The belly pan access cover is a 914 part. The 911 part is not even close. |
jt914-6 |
Aug 8 2009, 06:00 PM
I have the aluminium one on my 914. To make the one from my 914 work I had to make some brackets for the front. The support sticks down lower than the orignal 914 one and the cover hits it and has a gap in the front. I guess I'll have to put a couple of bends in the orignal cover...Here's a pic of the support.
Lo-Fi Version | Time is now: 17th May 2024 - 09:04 PM |
