QUOTE(jt914-6 @ Aug 8 2009, 07:21 PM)
Does anyone know if the 911 "protective cover" will work on a 914 that is using the I-beam aluminium support from a 911? I have a part number of 911 341 161 04. "74-89.
The 'auxillary support' is the same dimensionally, aluminum or steel, matters not if it's installed in a 914 or 911.
The belly pan access cover is a 914 part. The 911 part is not even close.
