What's that Click..click...click...? |
kenshapiro2002 |
Aug 13 2009, 05:33 PM
Senior Member Group: Members Posts: 1,441 Joined: 23-July 09 From: Bawlmer, MD Member No.: 10,598 Region Association: MidAtlantic Region |
When I turn my key all the way, right before it engages the starter, it (fuel pump? Solenoid?) goes "click...click...click" about ten times, with diminishing frequency and stops. Again, this is before engaging the starter.
Aug 13 2009, 05:38 PM
When I turn my key all the way, right before it engages the starter, it (fuel pump? Solenoid?) goes "click...click...click" about ten times, with diminishing frequency and stops. Again, this is before engaging the starter. its most likely your fuel pump building pressure. Have someone turn the key so you can track it down. After pressure is built up in the fuel system, its quiets down. Rich |
JOE M |
Aug 13 2009, 05:39 PM
Member Group: Members Posts: 293 Joined: 27-August 07 From: N.H Member No.: 8,042 Region Association: None |
im going with fuel pump.
kenshapiro2002 |
Aug 13 2009, 05:56 PM
orange914 |
Aug 13 2009, 06:11 PM
http://5starmediaworks.com/index.html Group: Members Posts: 3,371 Joined: 26-March 05 From: Ceres, California Member No.: 3,818 Region Association: Northern California |
That's what I thought. Just wondering of that's a "normal" fuel pump behavior as some are suggesting my current "fuel starvation" issue might be the pump. I still suspect carbs (gonna rebuild), or some kinda intake manifold leak thing. im going with fuel pump. fuel pump. it builds pressure for a few clicks then times out. UNLESS someone has bypassed and hot wired the pump to ign. seems to be common after 35 years and many hands of past owners |
jmill |
Aug 13 2009, 06:42 PM
When you find it chances are it'll look something like this.
You might want to change over to the CB rotary. Attached image(s) |
kenshapiro2002 |
Aug 13 2009, 06:59 PM
Yeah...I believe it's hanging out right next to my fuel filter...under the battery area. What is a "CB rotary" and why would I want to switch over? Thanks in advance for the guidance.
When you find it chances are it'll look something like this. You might want to change over to the CB rotary. |
jmill |
Aug 13 2009, 07:09 PM
Check it out here - http://www.cbperformance.com/catalog.asp?ProductID=577
It's much quieter and regulated at 3.5 psi. It will supply much more volume to your carbs at a constant pressure. Them tick tick jobs are too loud for me and drop off in pressure at higher flow. |
jmill |
Aug 13 2009, 07:19 PM
Here's the facet style: http://www.racerpartswholesale.com/product...acet_Fuel_Pumps
As you can see it flows 15 gph at 1 psi where the rotary flows 30 gph at 3.5. |
Cap'n Krusty |
Aug 13 2009, 07:27 PM
Yeah...I believe it's hanging out right next to my fuel filter...under the battery area. What is a "CB rotary" and why would I want to switch over? Thanks in advance for the guidance. When you find it chances are it'll look something like this. You might want to change over to the CB rotary. "Why"? Because the Facet pumps (or Empi, or whatever brand they are now) are junk. Were junk, are junk, and will always be junk. And they're not even cheap anymore, so they have NOTHING going for them. Except maybe the clicking ......... The Cap'n |
kenshapiro2002 |
Aug 13 2009, 07:32 PM
Thanks,
Ken Check it out here - http://www.cbperformance.com/catalog.asp?ProductID=577 It's much quieter and regulated at 3.5 psi. It will supply much more volume to your carbs at a constant pressure. Them tick tick jobs are too loud for me and drop off in pressure at higher flow. |
jmill |
Aug 13 2009, 09:00 PM
Yeah...I believe it's hanging out right next to my fuel filter...under the battery area. What is a "CB rotary" and why would I want to switch over? Thanks in advance for the guidance. You will want to relocate the pump. Placing it closer to the tank will let it push the fuel instead of pulling it. It works better that way. Most place it under the tank where they can get at the filter through the access hole. Having a less than stellar pump located so far from tank will contribute to fuel starvation issues. |
kenshapiro2002 |
Aug 13 2009, 09:22 PM
What's this one look to be?
ME733 |
Aug 13 2009, 09:30 PM
Senior Member Group: Members Posts: 842 Joined: 25-June 08 From: Atlanta Ga. Member No.: 9,209 Region Association: South East States |
(IMG:style_emoticons/default/popcorn[1].gif) There CAN BE a significant advantage to the CLICKING PUMP...If you pay attention....Sense, or time the clicks before it stops....IF IT KEEPS CLICKING you have a FUEL LEAK.,or a stuck and open float needle valve(now flooding your engine), or possably you are out of fuel (your guage broke),or ...can we think of some more advantages?...You do not hear it when the engine is running,so whats a little noise..use it as a tool. (IMG:style_emoticons/default/popcorn[1].gif)
kenshapiro2002 |
Aug 13 2009, 09:52 PM
Good point...makes sense. The clicking does stop if I wait until I hit the "ignition" with the key; it only clicks about 10 times I'm guessing.
(IMG:style_emoticons/default/popcorn[1].gif) There CAN BE a significant advantage to the CLICKING PUMP...If you pay attention....Sense, or time the clicks before it stops....IF IT KEEPS CLICKING you have a FUEL LEAK.,or a stuck and open float needle valve(now flooding your engine), or possably you are out of fuel (your guage broke),or ...can we think of some more advantages?...You do not hear it when the engine is running,so whats a little noise..use it as a tool. (IMG:style_emoticons/default/popcorn[1].gif) |
sww914 |
Aug 13 2009, 09:57 PM
Yeah...I believe it's hanging out right next to my fuel filter...under the battery area. What is a "CB rotary" and why would I want to switch over? Thanks in advance for the guidance. When you find it chances are it'll look something like this. You might want to change over to the CB rotary. "Why"? Because the Facet pumps (or Empi, or whatever brand they are now) are junk. Were junk, are junk, and will always be junk. And they're not even cheap anymore, so they have NOTHING going for them. Except maybe the clicking ......... The Cap'n Well said. They are only to be paired with Weber/Holley progressive carbs. (IMG:style_emoticons/default/smile.gif) |
jmill |
Aug 13 2009, 10:03 PM
jt914-6 |
Aug 13 2009, 10:11 PM
Driving & working on teeners 41 years Group: Members Posts: 1,786 Joined: 3-May 08 From: Bryant, Arkansas Member No.: 9,003 Region Association: South East States |
I agree with jmill. Relocate the NEW pump to the front along with a filter. Put the filter between the tank and pump. Consider a new line through the tunnel and all the way to the carb.
jmill |
Aug 13 2009, 10:18 PM
(IMG:style_emoticons/default/popcorn[1].gif) There CAN BE a significant advantage to the CLICKING PUMP...If you pay attention....Sense, or time the clicks before it stops....IF IT KEEPS CLICKING you have a FUEL LEAK.,or a stuck and open float needle valve(now flooding your engine), or possably you are out of fuel (your guage broke),or ...can we think of some more advantages?...You do not hear it when the engine is running,so whats a little noise..use it as a tool. (IMG:style_emoticons/default/popcorn[1].gif) That's a new one. I don't know too many folks that defend the clicky pump. If you keep your fuel system maintained you don't have to worry about leaks or stuck floats. How can having 1 psi at 15 gph be better than 30 gph at a constant 3.5 psi? At high rpm, when you need the most fuel, your clicky pump can't hang. Fuel pressure with that thing goes up and down like a yo-yo. The major disadvantages outweight your perception of any advantage. |
kenshapiro2002 |
Aug 13 2009, 10:23 PM
What access hole? Is there one in the pan below the tank?
Most place it under the tank where they can get at the filter through the access hole. |
Lo-Fi Version | Time is now: 13th May 2024 - 07:04 AM |
