Trunk Pivot, Blatant advertisement... |
JWest |
Mar 8 2004, 10:01 PM
My latest creation is a replacement for the failure-prone original rear trunk pivot base and bolt.
The new design moves the actual pivot from the bore in the hinge to a larger rod end which will not gall or rust. Once the old mount is removed, the new assembly can be installed after drilling four holes and a back-up plate reinforces the mounting area. The bolt-in design leaves adjustability to get the trunk alignment correct. Will work with the original torsion bars or the Camp914 shock kit. The price will be about $65 for a kit to do both sides. Whatcha think? Attached image(s) |
JWest |
Mar 8 2004, 10:02 PM
srfghj
F4i |
Mar 8 2004, 10:07 PM
914 DOG! Group: Benefactors Posts: 482 Joined: 22-December 03 From: AB Canada Member No.: 1,460 |
I'm on that like a fat kid on a smartie! (IMG:style_emoticons/default/clap56.gif) Now I just need to brush up on my 914 trivia.
Mar 8 2004, 10:09 PM
Resident German Group: Admin Posts: 41,623 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
looks good, but why? (IMG:style_emoticons/default/confused24.gif)
the original hinge plate thing is still available ... Andy |
F4i |
Mar 8 2004, 10:14 PM
They bust off though. Also because I had to replace my trunk and it does not quite line up correctly. I like it for the adjustment.
JWest |
Mar 8 2004, 10:18 PM
QUOTE(SirAndy @ Mar 8 2004, 10:09 PM) looks good, but why? (IMG:style_emoticons/default/confused24.gif) the original hinge plate thing is still available ... Andy Here are my reasons: Because my first 914 that was very low miles and very well cared for had a broken pivot. I don't like welding new parts on the car only to have them break again in a few years. Many people can't do the replacement themselves because they can't weld. When you replace the original it must be positioned perfectly (or really close at least) to have the trunk sit at the correct height when finished. Because this MUCH better design is not much more $ than the original parts. |
McMark |
Mar 9 2004, 01:23 AM
Make them weld it in. Bolt on stuff looks so tacky. Otherwise the kit looks good even though I agree with Andy.
JWest |
Mar 9 2004, 07:00 AM
QUOTE(markd@mac.com @ Mar 9 2004, 01:23 AM) Make them weld it in. Bolt on stuff looks so tacky. Otherwise the kit looks good even though I agree with Andy. The problem with welding it in is that it will rip off the thin sheet metal eventually. Bolting it on with a back-up plate alleviates this problem. |
TheCabinetmaker |
Mar 9 2004, 07:11 AM
James, I have a car in the shop now that needs both sides. Are they available now?
Thanks, Curt |
ChrisFoley |
Mar 9 2004, 07:13 AM
I am Tangerine Racing Group: Members Posts: 7,922 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Actually, if that plate was welded around the perimeter it would probably not tear out. There is very little twisting force applied, as there is in the original system.
I like it either way, bolted or welded. I have a number of sets of another bolt in solution, but I like this better. It looks sturdy enough to me, and it's adjustable. (IMG:style_emoticons/default/smile.gif) |
jfort |
Mar 9 2004, 09:03 AM
Senior Member Group: Members Posts: 1,135 Joined: 5-May 03 From: Findlay, OH Member No.: 652 Region Association: Upper MidWest |
just emailed camp914. this will work with that as i understand it. also, i assume you will provide good installation instructions as you did with the shifter. if so, count me in. when available?
JWest |
Mar 9 2004, 09:06 AM
QUOTE(jfort @ Mar 9 2004, 09:03 AM) just emailed camp914. this will work with that as i understand it. also, i assume you will provide good installation instructions as you did with the shifter. if so, count me in. when available? Actually, I just ordered trunk shox from Camp914 also! Instructions will be included. You can pre-order now and they will start shipping the end of next week. |
tat2dphreak |
Mar 9 2004, 09:09 AM
looks great! yet 1 more product/upgrade I need to buy from you, James (IMG:style_emoticons/default/biggrin.gif) though this one may be a while, the PO of my car fixed them, so they should last a little while. (IMG:style_emoticons/default/unsure.gif)
JWest |
Mar 9 2004, 09:25 AM
QUOTE(tat2dphreak @ Mar 9 2004, 09:09 AM) looks great! yet 1 more product/upgrade I need to buy from you, James (IMG:style_emoticons/default/biggrin.gif) though this one may be a while, the PO of my car fixed them, so they should last a little while. (IMG:style_emoticons/default/unsure.gif) Make sure those original pivots stay greased - that will extend the life considerably (and save your money for other cool stuff)! |
maf914 |
Mar 9 2004, 09:36 AM
James,
Looks good. Will it include a mounting template so that the location isn't guesswork? Mike |
JWest |
Mar 9 2004, 09:43 AM
QUOTE(maf914 @ Mar 9 2004, 09:36 AM) James, Looks good. Will it include a mounting template so that the location isn't guesswork? Mike The way I laid out the holes, you can fit the trunk pivot, line up the trunk, and drill 3 of the holes with the trunk fitted. The last hole can be drilled with the trunk hinged open a bit. This gets you as close as possible, and loose-fit holes allow you to adjust from there. |
Brad Roberts |
Mar 9 2004, 01:31 PM
It is a toss up for me. I dont even measure to weld the new ones in any more. They all fit back into the same place. The only ones I see ripped out are the ones where people have let the plastic rollers break away and/or let the pivot bolt gets so rusty that it seizes.
I like this part James. I see it as a good alternative for the home user who cant/doesnt weld and needs a solution. If people ask for it.. I'll sell it. B |
Scott S |
Mar 9 2004, 05:43 PM
Small Member Group: Members Posts: 1,697 Joined: 30-April 03 From: Colorado Member No.: 633 |
LOVE it. I can see serious fatigue on my anally watched/greased pivots. I have been opening the trunk like it is made of glass for over a year. As long as getting it indexed is explained, I am most definitely in for a pair - and the rear shock kit.
Great job (IMG:style_emoticons/default/pray.gif) |
IronHillRestorations |
Mar 9 2004, 09:03 PM
I. I. R. C. Group: Members Posts: 6,716 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
Another excellent solution James! A very nice bolt in set up with adjustability.
What I've been doing is welding some angle pieces (bent from 16ga) to reinforce the stock pieces. This is in an old Upfixen Der Porsche from PCA. Another thing I found in Upfixen was a mod to the pivot shoulder bolt. You machine a groove along the bearing surface of the bolt, drill down the center of the bolt and tap it for a grease fitting. Then a drill a small hole crossways through the bolt , and through your new groove. This way you can grease the shoulder bolt. Good work! PK (IMG:style_emoticons/default/cool.gif) |
Lo-Fi Version | Time is now: 6th May 2024 - 12:38 AM |
