My latest creation is a replacement for the failure-prone original rear trunk pivot base and bolt.
The new design moves the actual pivot from the bore in the hinge to a larger rod end which will not gall or rust.
Once the old mount is removed, the new assembly can be installed after drilling four holes and a back-up plate reinforces the mounting area. The bolt-in design leaves adjustability to get the trunk alignment correct.
Will work with the original torsion bars or the Camp914 shock kit.
The price will be about $65 for a kit to do both sides.
Whatcha think?
