Spark Plug GAp, with MSD |
jim_hoyland |
Aug 16 2009, 02:10 PM
Get that VIN ? Group: Members Posts: 9,312 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
I'm running a Bosch blue coil, Mallory unilite, and MSD 6. The MSD went in 2 weeks ago and I did not change the spark plug gap. Runs fine. Should the gap be increased ? or is it only increased if you run the Blaster coil.
messix |
Aug 16 2009, 02:31 PM
AKA "CLUTCH KILLER"! Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
.040 -.045 is safe.
J P Stein |
Aug 16 2009, 02:34 PM
MDG |
Aug 16 2009, 07:46 PM
Wolf in wolf's clothing. Group: Members Posts: 8,652 Joined: 3-February 09 From: Toronto Member No.: 10,018 Region Association: None |
MSD 6AL, Blaster Coil; gapped at .050 - works great on mine. The -6 that is.
yeahmag |
Aug 17 2009, 12:59 AM
Advanced Member Group: Members Posts: 2,422 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
Mallory Unilite, Mallory 6AL, and a Blue Coil - Gaped at .040 (NGK B6ES-11 is pre-gaped at .040")
jim_hoyland |
Aug 17 2009, 10:29 AM
yeahmag |
Aug 17 2009, 10:48 AM
Stock NGK replacement plug for the 914. The "-11" signifies the .040" pre-gap. The advantage there is that the plug is built for the gap. Otherwise, bending the electrode out on a "standard" plug will result in a non-parallel plug gap.
jim_hoyland |
Aug 17 2009, 02:55 PM
Stock NGK replacement plug for the 914. The "-11" signifies the .040" pre-gap. The advantage there is that the plug is built for the gap. Otherwise, bending the electrode out on a "standard" plug will result in a non-parallel plug gap. Thanks for the lesson; never knew that. How is a standard NGK gap plug designated ? |
J P Stein |
Aug 17 2009, 02:58 PM
I mis-spoke, I'm afraid. The blue coil comes up short with a big gap on plugs whem used over 6K rpms firing 6 cylinders. It may work out fine for those not going there.
jim_hoyland |
Aug 17 2009, 04:13 PM
I mis-spoke, I'm afraid. The blue coil comes up short with a big gap on plugs whem used over 6K rpms firing 6 cylinders. It may work out fine for those not going there. My '75 is a 1.8L 4 banger with the L-Jet; nothing special, but I did upgrade to the Mallory and MSD. Truly runs smoother through all RPMs. |
yeahmag |
Aug 17 2009, 04:20 PM
The standard NGK is just a B6ES (no -11 designation)
Lo-Fi Version | Time is now: 29th May 2024 - 06:20 AM |
