FS: 76 2.0 motor $500- 996/993 wheels $400, Ran with unknown miles on it |
JRust |
Aug 16 2009, 09:13 PM
914 Guru Group: Members Posts: 6,307 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
This motor is out of a parts car. Had it running briefly when pulled. I would plan on a rebuild. I don't have leak down numbers on it. I am keeping the FI for another project. This is the complete motor with tin less the fuel injection. You could run it as is if your in need. While it is out is the best time to pull it apart.
76 2.0 motor $500 I do have a nice set of dual weber 40's I would include with linkage for an additional $450 The wheels are good solid wheels. The rears are 16x8 & fronts are 16x7. The do require spacers 1" for fronts 2" for rears. Also you need flares in the rear to fit them under. Wheels are chrome & in very good shape. $400 for wheels without tires Attached image(s) |
jmill |
Aug 17 2009, 11:27 AM
Do you have some pics of the carbs and linkage? I have a couple of engines but I'm interested in the carbs.
JRust |
Aug 20 2009, 02:30 PM
Do you have some pics of the carbs and linkage? I have a couple of engines but I'm interested in the carbs. Sorry I'm only going to sell the carbs with the motor. I would prefer to keep the carbs as backup Obviously a local pickup is prefered. I will put it on a pallet & ship it though |
tat2dphreak |
Aug 20 2009, 03:07 PM
if you were close I'd buy it for the crank and heads.
JRust |
Aug 28 2009, 08:50 PM
JRust |
Sep 22 2009, 11:46 PM
Just added the wheels. They are a little dirty in the pics but they are what I had.
UberElectricEagle |
Sep 24 2009, 09:13 PM
atomic Group: Members Posts: 43 Joined: 10-August 09 Member No.: 10,659 Region Association: None |
UberElectricEagle |
This motor is out of a parts car. Had it running briefly when pulled. I would plan on a rebuild. I don't have leak down numbers on it. I am keeping the FI for another project. This is the complete motor with tin less the fuel injection. You could run it as is if your in need. While it is out is the best time to pull it apart. 76 2.0 motor $500 I do have a nice set of dual weber 40's I would include with linkage for an additional $450 The wheels are good solid wheels. The rears are 16x8 & fronts are 16x7. The do require spacers 1" for fronts 2" for rears. Also you need flares in the rear to fit them under. Wheels are chrome & in very good shape. $400 for wheels without tires Do you still have the motor? |
Lo-Fi Version | Time is now: 19th May 2024 - 11:32 PM |
