This motor is out of a parts car. Had it running briefly when pulled. I would plan on a rebuild. I don't have leak down numbers on it. I am keeping the FI for another project. This is the complete motor with tin less the fuel injection. You could run it as is if your in need. While it is out is the best time to pull it apart.
76 2.0 motor $500
I do have a nice set of dual weber 40's I would include with linkage for an additional $450
The wheels are good solid wheels. The rears are 16x8 & fronts are 16x7. The do require spacers 1" for fronts 2" for rears. Also you need flares in the rear to fit them under. Wheels are chrome & in very good shape. $400 for wheels without tires
