jhadler |
Long term tinkerer... ![]() ![]() ![]() Group: Members Posts: 1,879 Joined: 7-April 03 From: Lyons, CO Member No.: 529 ![]() |
Just starting to clear out my surplus of parts.
I have a 96 mm Piston and Cylinder set from NPR. Set includes pistons, rings, jugs, pins and clips. These are primarily for use with a short stroke crank motor (1.8L or 1.7L - 66 mm). I have been told that they can also be used on a longer stroke crank (2.0L - 71 mm) with the use of spacer shims under the jugs. Pistons have never been used, only test fitted once, but the heads were never torqued down. $300 for the set. -Josh |
Lo-Fi Version | Time is now: 11th July 2025 - 02:01 AM |
