Just starting to clear out my surplus of parts.
I have a 96 mm Piston and Cylinder set from NPR. Set includes pistons, rings, jugs, pins and clips.
These are primarily for use with a short stroke crank motor (1.8L or 1.7L - 66 mm). I have been told that they can also be used on a longer stroke crank (2.0L - 71 mm) with the use of spacer shims under the jugs.
Pistons have never been used, only test fitted once, but the heads were never torqued down.
$300 for the set.
-Josh
