Interior Long/Firewall reinforcement, Necessity is the mother of invention |
ruddyboys |
Mar 10 2004, 01:01 PM
Hummel eigentümer Group: Members Posts: 594 Joined: 3-March 04 From: Monroe, NY Member No.: 1,749 Region Association: North East States |
Engman, I have almost the simular problem on the passenger side, I hope you can keep the pictures comming on the progress.
Pat- |
Brad Roberts |
Mar 10 2004, 05:16 PM
Mark,
Dont put the holes in them. Dimple the area that covers our stock access holes so we know where they are in case we need to cut through them, but make this area solid. Every holes weekens the part. B |
Engman |
Mar 10 2004, 07:25 PM
Zoisite Group: Benefactors Posts: 1,349 Joined: 25-March 03 From: New Albany, IN Member No.: 475 |
I will put a 1" hole where these are.... just finished revising the layout..... added more easy form bends- hand bend to fit the relief for the hand brake, rear 45 degree bend and across the back then weld it solid. Added the .25 rosette weld holes and made several minor fit modifications. Going to laser cut a couple of sets hopefully this week and then e-coat paint them and install. Brad - send me a pm as to where you want a set sent.
M |
Brad Roberts |
Mar 10 2004, 10:27 PM
Thanks Mark. I have a car on the rack RIGHT NOW that I had planned on installing these into. I just finished replacing his control arm ear and repairing a ton of damage from a rear end collision. The frame is still weak and flexible. This kit will work GREAT for him.
We do need to work on the price however. It needs to be about 200$ out the door. B |
Bleyseng |
Mar 10 2004, 10:34 PM
sounds like ChrisR car. This kit could be used by a ton of cars.
Geoff |
Brad Roberts |
Mar 10 2004, 10:38 PM
Yep. Wait until I tell Chris he has been running around on a bent control arm. I installed the control arm today and noticed a fat "bend" in the arm. I cant get the toe set properly now that it has a solid ear in the proper location.
I know how much the car means to him.. but I would have bought another tub (even if it has personal value.) B |
Lo-Fi Version | Time is now: 5th May 2024 - 08:18 PM |
