Quick timing/advance question. |
Ferg |
Aug 22 2009, 03:32 PM
914 Guru Group: Members Posts: 5,948 Joined: 8-January 03 From: Boulder CO Member No.: 116 Region Association: None |
Just did a tune up to stock specs 2.0 Djet.
Runs good, but I think I can do a little better. I live at 5500 ft elevation., all my driving goes higher. I want to run a few degree's of advance. Turn the dizzy clockwise for advance right???? I just have a inductive light, how far out of the notch would I want my red mark for a couple of degrees??? Pencil width, more less? TIA Ferg |
tod914 |
Aug 22 2009, 04:25 PM
Advanced Member Group: Members Posts: 3,755 Joined: 19-January 03 From: Lincoln Park, NJ Member No.: 170 |
counter clockwise. You'll hear the rpm's increase. Ferg on the Pelican site is a template if you can't offset your timing light. If you can offset your timing light, you'll be able to do it that way instead of the templete. 30 degrees instead of the 27 and use the zero mark on the fan (should be white instead of the red 27 mark).
Ferg |
Aug 22 2009, 05:19 PM
thanks, forgot all about that template. that will help.
Gint |
Aug 23 2009, 08:34 AM
Mike Ginter Group: Admin Posts: 16,075 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
Or you can come over here and borrow my timing light so you know you've only advanced it a few degrees. Here at altitude you can almost always add a few degrees of advance. Been doing it for years. That's why I bought a adjustable timing light.
Ferg |
Aug 23 2009, 08:43 AM
Thanks Mike,
I think I got it, seems spot on now, just a tad advanced. Next time I'm over I'll check it with your light. |
SLITS |
Aug 23 2009, 08:53 AM
52.5 mm to the right of the TDC mark is 27 degrees. You can divide and figure out how many degrees/mm and make a new mark.
Gint |
Aug 23 2009, 09:00 AM
Did you use a pile of rocks to do that math Gramps? Life before tools... (IMG:style_emoticons/default/laugh.gif)
Lo-Fi Version | Time is now: 20th May 2024 - 02:17 PM |
