Man....my car really flies, The cool crisp summer evenings + turbo = blast off..... |
iamchappy |
Aug 22 2009, 10:24 PM
I really like it...., What a thrill ride....Fun meter off the scale... (IMG:style_emoticons/default/piratenanner.gif) Running 1 Bar of boost and for some reason the clutch has not slipped in the last two days. (IMG:style_emoticons/default/confused24.gif) |
degreeoff |
Aug 22 2009, 10:40 PM
I like big butts and I can not lie! Group: Members Posts: 1,622 Joined: 9-February 03 From: Booowieeee MD (near DC) Member No.: 275 Region Association: MidAtlantic Region |
I would LOVE to know your 0-60 times....it must be balls fast. BTW what sort of HP do you have?
Josh |
iamchappy |
Aug 22 2009, 10:52 PM
I think around 400 + or - a few.. No official dyno sheets just an estimate comparing
my engine to other similar builds. The short gears M,S,Z add a few more seat in the pants hp to it. The engine has the same bore and stroke as the IMSA 935's at 70.4-97mm. Early large port and valve SC heads twin plugged, Euro fuel distributor, 1986 930 ported intake with a RPM activated extra fueler. SC cams- K27 7200 turbo. I bumped the boost up the other day from 11 lbs back up to 14.5, the clutch was slipping at 11 but for what reason that i cant understand, it has been holding the past few days. Running 14.5 of boost is noticeably way more power. |
sean_v8_914 |
Aug 22 2009, 10:55 PM
why does your car belong to a fly? did you give it to the fly or did he pay cash?
degreeoff |
Aug 22 2009, 10:57 PM
Man that is just S I C K.....how is it that you keep the power down?
iamchappy |
Aug 22 2009, 11:04 PM
Man that is just S I C K.....how is it that you keep the power down? I dont, but when it hooks up and the clutch holds shifting through all the short gears happens quickly... I have been thinking about using a Kevlar clutch from Renegade because of the clutch not holding, when it didnt hold at 11 i said what the hell might as well kick it back up to 14.5 as the clutch still held through 3rd and only slipped in 4th and 5th. Now it wants to hold in all gears. (IMG:style_emoticons/default/confused24.gif) |
Justinp71 |
Aug 23 2009, 12:29 AM
Senior Member Group: Members Posts: 1,583 Joined: 11-October 04 From: Sacramento, CA Member No.: 2,922 Region Association: None |
Thats Awesome.
I couldn't imagine a car with almost double the horse I have now. |
championgt1 |
Aug 23 2009, 01:10 AM
Don't embarrass me Filmore! Group: Members Posts: 2,680 Joined: 3-January 07 From: Tacoma, Washington Member No.: 7,420 Region Association: Pacific Northwest |
A light car with 400 horse. (IMG:style_emoticons/default/piratenanner.gif)
balljoint |
Aug 23 2009, 03:26 PM
Wow.
I am trying to like you Chappy, I really am, but you're not making it easy. (IMG:style_emoticons/default/biggrin.gif) |
ClayPerrine |
Aug 23 2009, 10:19 PM
Life's been good to me so far..... Group: Admin Posts: 15,459 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Man that is just S I C K.....how is it that you keep the power down? I dont, but when it hooks up and the clutch holds shifting through all the short gears happens quickly... I have been thinking about using a Kevlar clutch from Renegade because of the clutch not holding, when it didnt hold at 11 i said what the hell might as well kick it back up to 14.5 as the clutch still held through 3rd and only slipped in 4th and 5th. Now it wants to hold in all gears. (IMG:style_emoticons/default/confused24.gif) I know a local guy here who has a brand new Kevlar clutch disk for a 915 gearbox for sale. Supposedly they are lousy for use on the street...grabby. Let me know if you want me to find out how much he wants for it... |
iamchappy |
Aug 23 2009, 10:47 PM
I need a 9" or 228mm clutch, Renegade has them for 195.00. I guess it's all in how
you bed them in, if you go very easy on them for about 500 miles they are suppose to have up to 45% more holding power over organic. if the clutch is not bedded in properly they dont work well. |
rick 918-S |
Aug 23 2009, 11:23 PM
Hey nice rack! -Celette Group: Members Posts: 20,455 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
I have a puck style kevlar without spring center. I can get it to squeal like a tire chirp on engagement in first sometimes but it always grabs hard without chatter. I have a stage II Kennedy PP. I've had good luck so far. I know it grabs hard enough to destroy my 901 or bust a CV joint if I'm not paying attension during hard excelleration. I would never drop the clutch. It grabs that good. I alway release it then hit the hammer. The one time I dropped it I snapped a CV without even spinning a tire. Oh ya, it's stock 914 size diameter.
Lo-Fi Version | Time is now: 13th May 2024 - 06:48 PM |
