a quick question, starter for a 2.0 |
Jerry |
Aug 23 2009, 06:02 PM
Member Group: Members Posts: 413 Joined: 7-April 05 From: Conroe, Texas Member No.: 3,892 Region Association: None |
Hey, I have a quick question.... a guy around here has a starter that he says is for a 1.7 or a 1.8 part number 311911023D will that fit a 2.0 ?? I thought they were all the same....is there a difference?? |
brp986s |
Aug 23 2009, 06:15 PM
Member Group: Members Posts: 434 Joined: 27-September 07 From: los angeles Member No.: 8,167 |
All 914/4 and /6 use the same starter. Put down the beer and get to work.
Aug 23 2009, 07:42 PM
914 Idiot Group: Members Posts: 14,984 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
I don't believe the 311 starter will work on any of the 914s. At least, not for long. Isn't that the "automatic" starter that is incorrectly listed in most parts books as the one for the 914?
Hmm, the factory parts book seems to call for a "003" part number for the starter? Curious. Regardless, I don't think any starter for the Type III ("311" part prefix) is correct for the 914. --DD |
SLITS |
Aug 23 2009, 09:56 PM
Look at the nose of the starter. If the Bendix gear is on a shaft stickin out of the front plate, it is a SR15X Type 1 Beetle starter and won't fit.
If the Bendix is even with the front plate of the starter with no shaft sticking out beyond the gear, it is more than likely and SR17X or "VW Automatic Starter" which would be the correct one for Teeners and Assdraggers. |
Jerry |
Aug 23 2009, 09:59 PM
Thanks, Dave.....that's a real help.
Anybody else have an opinion????? |
underthetire |
Aug 24 2009, 10:49 AM
Thanks, Dave.....that's a real help. Anybody else have an opinion????? Just did my starter a couple weeks ago. 1st one correct, second incorrect. Attached image(s) |
Jerry |
Aug 24 2009, 11:15 PM
Thanks alot........that solved the problem. This guy has the wrong one
underthetire |
Aug 25 2009, 09:28 AM
Thanks alot........that solved the problem. This guy has the wrong one I have the part number for the correct one for 39 bucks at kragens. Just don't let the Crusty one know your getting a starter there! (IMG:style_emoticons/default/poke.gif) |
zymurgist |
Aug 25 2009, 12:15 PM
"Ace" Mechanic Group: Members Posts: 7,411 Joined: 9-June 05 From: Hagerstown, MD Member No.: 4,238 Region Association: None |
I bought my 911 starter from the local NAPA store. It was a "remanufactured in Germany" starter that I've been quite happy with.
Lo-Fi Version | Time is now: 11th May 2024 - 09:49 AM |
