DR Evil...southern ca transmission evaluation pics, Unless you're into greasy gears, this thread is not 4 u |
computers4kids |
Aug 23 2009, 07:25 PM
Love these little cars! Group: Members Posts: 2,443 Joined: 11-June 05 From: Port Townsend, WA Member No.: 4,253 Region Association: None |
GOAL: To install the "H" gear that I purchased in one of the three transmissions and have a good transmission for my v8 car.
I have 3 stock 914 transmissions: 1) a tailshifter that looks like it has been converted to a sideshifter..is that possible. The only thing missing is the shift console and shift fork. I recieved this transmission with a parts car 4 years ago...no history. When I pulled the gear stack it looks practically brand new inside...that is from laymen's eyes. 2) a sideshifter that had a broken ear (you sent me a tailcone already). This one was in a car for sale that a drunk hit the car while it was parked. I bought the car as a parts car, but never drove the car. All looks OK to me inside but not as pretty as the tailshifter gear stack. 3) a perfect shifting sideshifter transmission currently in my v8 car. No howling or leaks...no real reason to open it up. I have pulled transmission one and two apart and will bring to the clinic along with the spare sideshifter tail cone. I'm debating whether to pull the v8 transmission and bring it. If the two have what it takes to make one good transmission with the H gear, it would make sense to me to save the transmission in my car for the spare...just in case (IMG:style_emoticons/default/happy11.gif) Looks like the innards of the tailshifter is in fantastic shape. Would I put the tailshifter gear stack and matching differential (31 teeth) into the sidshifter case?? If you think the gear stacks are questionable, I can always pull the good transmission and bring it as well. The two gear stacks(IMG:http://computers4kidshome.com/clinic/stack1.jpg) (IMG:http://computers4kidshome.com/clinic/stack2.jpg) (IMG:http://computers4kidshome.com/clinic/stack3.jpg) Close-ups of the tailshifter stack (IMG:http://computers4kidshome.com/clinic/1.jpg) (IMG:http://computers4kidshome.com/clinic/2.jpg) (IMG:http://computers4kidshome.com/clinic/3.jpg) (IMG:http://computers4kidshome.com/clinic/4.jpg) (IMG:http://computers4kidshome.com/clinic/5.jpg) The two differnetials, one on the left is out of the tailshifter 9143322120 numbers on the sideshifter diff (31teeth) X22.53 numbers on the tailshifter diff.(31teeth) (IMG:http://computers4kidshome.com/clinic/diff1.jpg) (IMG:http://computers4kidshome.com/clinic/diff2.jpg) Hey, I even followed your directions (IMG:style_emoticons/default/biggrin.gif) |
sww914 |
Aug 23 2009, 09:42 PM
Sorry, you're screwed. (IMG:style_emoticons/default/smile.gif)
SLITS |
Aug 23 2009, 09:51 PM
All looks pretty good to me.
Look at the ring on the diff and look at the wear pattern on the teeth from the pinion gear. If the wear is even on all the teeth it was set up correctly. Don's switch the diffs into a different case as you will have to pay about $300+ to get the ring and pinion reset for proper lash & depth. |
Dr Evil |
Aug 23 2009, 09:56 PM
Man, you are going to learn a LOT at the clinic. Some of those pics are worthless as far as diagnostics (IMG:style_emoticons/default/wink.gif) Bring them both, keep the parts labeled so you know what goes in what box. Are you keeping 1st? That is the big $$ part and if you are not you are gonna be fine with what you have most likely. The tail one looks like 3rd is poo, not normal.
Jax914 |
Aug 24 2009, 09:10 PM
Schwienhund Rennenmannshaft Group: Members Posts: 138 Joined: 7-August 06 From: Jacksonville, FL Member No.: 6,602 Region Association: South East States |
Just .02....to echo the good Dr.
About all you can tell from these pics is the slight rounding on that one gear. The main things you'll need to check are the synchros and bearings in the intermediate plate. Then the clearances on the forks.... make sure you don't mix and match....keep them all separate. |
computers4kids |
Aug 25 2009, 08:52 AM
Man, you are going to learn a LOT at the clinic. Some of those pics are worthless as far as diagnostics (IMG:style_emoticons/default/wink.gif) Just .02....to echo the good Dr. About all you can tell from these pics is the slight rounding on that one gear. The main things you'll need to check are the synchros and bearings in the intermediate plate. Then the clearances on the forks.... make sure you don't mix and match....keep them all separate. I have been heavy into 914s for the last 5 years and other than the transmission, I can't think of too much I haven't worked on. The transmission has always been "no mans land." (IMG:style_emoticons/default/smile.gif) The clinic will be great time to face my fears (IMG:style_emoticons/default/chowtime.gif) and dig in and learn something. Actually, after pulling my first gear stacks I already am feeling a little less nervous...of course, knowing the Dr. would be there at the clinic gave me courage. (IMG:style_emoticons/default/happy11.gif) |
Lo-Fi Version | Time is now: 11th May 2024 - 12:05 AM |
