| Rod |
Aug 26 2009, 04:49 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 617 Joined: 1-January 08 From: Farnham UK Member No.: 8,526 Region Association: England |
I can get my hands on this engine very reasonably would it be a good choice for a 914 swap or would a 3.0 or a 3.2 be a better bet?
Engine number 6151404 1975 2.7 with cis |
Rod Is this 911 engine any good for a 914 swap? Aug 26 2009, 04:49 PM
thesey914 Rod, sounds like the 150hp/235lbs/ft version. Has ... Aug 26 2009, 06:06 PM
SLITS A decent 2.7L will give you wood! Aug 26 2009, 07:34 PM
lotus_65 i would like it...
:) Aug 26 2009, 07:58 PM
Vacca Rabite What shape is the motor in?
Has it had all the 2.7... Aug 26 2009, 08:47 PM
pete-stevers not to discourage a six build but why did theat 2.... Aug 26 2009, 09:16 PM
Mike Gilbert in the long run you will be better off with the 3.... Aug 27 2009, 03:51 PM
Cupomeat I agree with Mike, in that if you are shopping for... Aug 27 2009, 04:04 PM
Rod
I hope this helped.
Helps a lot :) Enough to ke... Aug 27 2009, 04:20 PM
J P Stein There are a lot of opinions here but apparently no... Aug 27 2009, 06:05 PM
ArtechnikA
I know bout 2.7s. This one *may* be F/S in a coup... Aug 27 2009, 07:59 PM
J P Stein
I know bout 2.7s. This one *may* be F/S in a cou... Aug 27 2009, 08:04 PM
ArtechnikA
Be advised, it uses race gas.......but it's a... Aug 27 2009, 08:10 PM
J P Stein
Be advised, it uses race gas.......but it's ... Aug 27 2009, 08:26 PM
ArtechnikA
A good twin plug set-up is pricy.
yes, but I... Aug 28 2009, 06:35 AM
J P Stein
yes, but I... Aug 28 2009, 01:45 PM
BKLA I'm with JP on this... a 2.7 can be quite a ni... Aug 27 2009, 08:05 PM
J P Stein
I'm with JP on this... a 2.7 can be quite a n... Aug 27 2009, 08:09 PM
sixnotfour JP that distributor I sold you is for sale on 911... Aug 27 2009, 09:22 PM
J P Stein Yeah, I should'a bought 100 of em'........... Aug 27 2009, 09:45 PM
degreeoff I like mine.....I am redoing a bad mistake now tha... Aug 27 2009, 09:51 PM
Vacca Rabite
Itwas a sick (as in poor running) engine in my te... Aug 28 2009, 10:46 AM
GeorgeRud A properly prepared 2.7 is a hoot, and a lot of fu... Aug 27 2009, 10:44 PM
GreatPumpkin NO,
Dont listen to these guys... That will never... Aug 28 2009, 11:24 AM
Cupomeat J P Stein, thanks for fixing my mistake as I did n... Aug 28 2009, 02:08 PM
pete-stevers alas...the 2.7 guys seem to have dominated....yup ... Aug 28 2009, 03:14 PM
alas...the 2.7 guys seem to have dominated....yup... Aug 28 2009, 04:02 PM
ArtechnikA
alas...the 2.7 guys seem to have dominated....yup... Aug 28 2009, 06:32 PM
Ferg When I had my six, I took the 2.7 out and put in a... Aug 28 2009, 04:12 PM
SLITS How can you say that Ferg ... you don't keep a... Aug 28 2009, 04:48 PM
How can you say that Ferg ... you don't keep ... Aug 28 2009, 05:07 PM
J P Stein The 3.0L 9eleben engine is the most reliable engin... Aug 28 2009, 06:58 PM
pete-stevers jeez....i didn't think any one ever noticed th... Aug 31 2009, 10:29 PM![]() ![]() |
Lo-Fi Version | Time is now: 17th November 2026 - 03:15 PM |
