Best option: shim or shave for BMW calipers? |
Wardsweb |
Aug 27 2009, 01:52 PM
Member Group: Members Posts: 60 Joined: 8-September 08 From: San Antonio, TX Member No.: 9,527 Region Association: None |
Should I use a thin wheel spacer or grind down the BMW calipers so they don't rub the Fuchs? Everything is already mounted with a washer on each lug so they don't rub, but I want a more permanent solution. I don't need much but wanted some insight before I just grind on the caliper.
Lo-Fi Version | Time is now: 1st June 2024 - 04:14 AM |
