> Heat Exchangers, 1.8 and 2.0 the same??
19144jt
post Aug 27 2009, 05:26 PM
I have a chance to buy a 2.0 big bore with carbs and sst heat exchangers. I have a 1.8 and already have two sets of sst heat exchangers for that motor. Will the 1.8's I have work for the 2.0 big bore? He wants an extra $300 for the heat exchangers for the 2.0 and I know that's a fair price but I don't want to buy them If I don't have to.
John (IMG:style_emoticons/default/confused24.gif)
tat2dphreak
post Aug 27 2009, 05:53 PM
stoya, stoya, stoya
yes, you can use 1.8 SSI H/Es on a 2.0... and they are the same ID as the 2.0...
you cannot use a 2.0 muffler on the 1.8 H/Es...
post Aug 27 2009, 06:00 PM
Resident German
QUOTE(19144jt @ Aug 27 2009, 03:26 PM) *
How big is that big bore?
The SSI's are larger than stock in dia. but if the motor is much bigger than 2.0L, you might be better off getting a set of headers ...
(IMG:style_emoticons/default/shades.gif) Andy
19144jt
post Aug 27 2009, 06:14 PM
I don't know yet how big it is. He is saying that it was a stock 914 2.0 at one time and now has a big bore set of pistons and cyls and a cam that isn't compatible with FI. He thought that the displacement was 2156 but I haven't seen that one around yet. I have seen 2056. I will know more when he sends me some pics and more info. He says the guy he bought it from was autXing the car so who knows. Sirandy, does headers = no heat exchangers? I live where it snows and can get pretty cold and would drive during the winter so I would want the heat in the car. Yea, I know I'm a panzy!
John (IMG:style_emoticons/default/biggrin.gif)
tat2dphreak
post Aug 27 2009, 07:05 PM
stoya, stoya, stoya
yep, if you go headers, you got no heat... I guess youcould get an old bus gasoline heater and retrofit it tho
gregrobbins
post Aug 28 2009, 12:05 AM
Member: Team NARP
2056 is a common upgrade using a stock crank/rods and 96mm pistons. The Stainless Steel heat exchangers should work fine.
Find out all you can about the motor. Compression test/leakdown test would be nice. You can hurt motors autocrossing. Ask me how I know.
- Lo-Fi Version Time is now: 14th March 2026 - 08:33 AM
