FS: 2.0L Engine Parts |
solex |
Aug 29 2009, 11:11 AM
Senior Member Group: Members Posts: 789 Joined: 12-January 05 From: Long Island, NY Member No.: 3,439 Region Association: North East States |
I had some engine problems with my recent 2.0 L rebuild, a foreign contaminate was in the oil and ruined the case, lifters and pistons and cylinders. My original intent was to reuse the parts but I found a deal on a rebuilt engine that had the same exact specifications as mine, so these parts are for sale, shipping will be additional, please email with your zip and I can quote on shipping.
NEW PARTS WITH LESS THEN 200 MILES - HAM rebuilt stock 2.0 L heads. There are 2 cracks on the guide fairings at the casting seaming, I was assured that these will not present a problem but dual springs cannot be used on the head. [ $700, 30 lbs ] - German Mahle pistons and cylinders includes wrist pins and keepers, Was examined by a professional and the cylinders would be a good candidate to bore for 96 mm pistons. The pistons, cylinders, wrist pins and keepers are included all come in the original Mahle box. [ $75.00, 40 lbs ] - Raby Rods stock rods [$ 150.00, 12 lbs] - Resurfaced stock flywheel with hardware [ $100.00, 25 lbs] PARTS WITH UNKNOWN MILES - Crank Shaft with Distributor and Cam gear, visual inspection no problems [ $100, 25 lbs] - Rockers and push rods [ $75, 15 lbs] OTHER PARTS - US Spec 2.0 L Pistons, Cylinders, wrist pins and keepers 2 pistons have a minor dent, cylinders have all fins and can be honed. Pistons have been stamped with "Ger. KS" will probably need new rings. [ $ 50.00, 40 lbs) Attached thumbnail(s) Attached image(s) |
solex |
Aug 29 2009, 11:13 AM
flywheel, crank, rockers
Attached thumbnail(s) |
solex |
Aug 29 2009, 11:14 AM
us pistons and cylinders & Euro Mahle Cylinder
pilothyer |
Aug 29 2009, 05:39 PM
Member Group: Members Posts: 838 Joined: 21-May 08 From: N. Alabama Member No.: 9,080 Region Association: South East States |
I would be interested in the Len Hoffman rebuilt 2.0 liter heads, pending further information...I will pm you my phone number and we can discuss the details.....shipping will be to 35603....Thanks Jerry
solex |
Aug 30 2009, 10:22 AM
cylinder side of the heads
solex |
Sep 5 2009, 09:01 AM
The following are still available:
--> 2.0 US spec pistons and cylinders --> Resurfaced flywheel All other parts are sold pending payment |
solex |
Sep 9 2009, 09:09 PM
--> Mahle Euro Spec pistons and cylinder ($75) --> 2.0 L Crank Shaft ($100) ------> mains 1,2 = 2.361" (could not measure #3 as the gears are still on) ------> main 4 = 1.574" ------> rods = 1.968" --> Raby Stock Rods ($150) --> rockers, push rod tubes and push rods ($75) --> 2.0 US spec pistons and cylinders ($50) --> Resurfaced flywheel ($100) --> Impeller and hub ($80) --> Heads sold pending payment |
Lo-Fi Version | Time is now: 20th May 2024 - 06:00 AM |
