I had some engine problems with my recent 2.0 L rebuild, a foreign contaminate was in the oil and ruined the case, lifters and pistons and cylinders. My original intent was to reuse the parts but I found a deal on a rebuilt engine that had the same exact specifications as mine, so these parts are for sale, shipping will be additional, please email with your zip and I can quote on shipping.
NEW PARTS WITH LESS THEN 200 MILES
- HAM rebuilt stock 2.0 L heads. There are 2 cracks on the guide fairings at the casting seaming, I was assured that these will not present a problem but dual springs cannot be used on the head. [ $700, 30 lbs ]
- German Mahle pistons and cylinders includes wrist pins and keepers, Was examined by a professional and the cylinders would be a good candidate to bore for 96 mm pistons. The pistons, cylinders, wrist pins and keepers are included all come in the original Mahle box. [ $75.00, 40 lbs ]
- Raby Rods stock rods [$ 150.00, 12 lbs]
- Resurfaced stock flywheel with hardware [ $100.00, 25 lbs]
PARTS WITH UNKNOWN MILES
- Crank Shaft with Distributor and Cam gear, visual inspection no problems [ $100, 25 lbs]
- Rockers and push rods [ $75, 15 lbs]
OTHER PARTS
- US Spec 2.0 L Pistons, Cylinders, wrist pins and keepers 2 pistons have a minor dent, cylinders have all fins and can be honed. Pistons have been stamped with "Ger. KS" will probably need new rings. [ $ 50.00, 40 lbs)
