2 empty plastic tubes coming up from the drivers side, through the long and across the firewall??? |
bandjoey |
Sep 1 2009, 10:36 PM
bandjoey Group: Members Posts: 4,926 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
What are these? Coming out of the Drivers Long and behind the heater fan and stop under the battery?
Totally empty inside. Looks factory? Ps. don't ask about the red wire. PO's answer to fuel pump wiring I need to replace. Attached thumbnail(s) |
ahdoman |
Sep 1 2009, 10:57 PM
It's phonetic...Ah-D-O-Man (Audioman) Group: Members Posts: 667 Joined: 7-November 05 From: Santa Clarita, Ca. Member No.: 5,084 Region Association: Southern California |
Looks like your tubes for the carbon canister on the gas tank. They provide the suck / blow from the engine to the canister.
championgt1 |
Sep 1 2009, 11:00 PM
Don't embarrass me Filmore! Group: Members Posts: 2,680 Joined: 3-January 07 From: Tacoma, Washington Member No.: 7,420 Region Association: Pacific Northwest |
I have the plastic tubes like that. They come out of the drivers side but they end under the relay board. They are for the charcoal canister up front. Never seen any as long as yours though. If that is what they are.
IronHillRestorations |
Sep 2 2009, 09:01 AM
I. I. R. C. Group: Members Posts: 6,717 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
Those are part of the fuel vapor recovery system. There's no reason to remove it. One of those connects (with a rubber line) to the impeller housing and the other one to the air intake of your FI or carbs.
dangrouche |
Sep 2 2009, 09:13 AM
dangrouche Group: Members Posts: 550 Joined: 1-May 04 From: San Francisco Bay Area Member No.: 2,012 Region Association: None |
looks like the PO may have pulled both lines into the engine bay; you can confirm if there is the absence of those two lines by looking at the brake supply reservoir. there might be two holes where those lines used to occupy in that area. since you have carbs, I could see a PO pulling those into the engine bay, but realized he should not have and was waiting for an opportunity to put it back
Lo-Fi Version | Time is now: 13th May 2024 - 07:23 PM |
