FS/ 1973 2.0, Neve thought I would sell this one but life changes. |
southernmost914 |
Sep 2 2009, 05:46 PM
KEY WEST/HAVANA Tunnel Authority Group: Members Posts: 338 Joined: 16-October 07 From: Key West/ St. Augie, Fl USA Member No.: 8,234 Region Association: South East States |
I figured I would offer it here before it goes on Ebay. $14000.00 Way more invested than will ever get back. Worth the drive to KW from central Florida. If you want any photo of some thing specific, no problem. Formaly a CA. car that found its way to South Florida. It was Kevin Wheeler personal daily driver when I purchased it.
PORSCHE 914 2.0 VIN# 4732917428 Spec sheet BODY: Less than 2000 miles since completion. Over restored Show finish. Car was painted one year ago. No scratches or dings. Rear suspension console( cracked not rusted ) was repaired by KMW Motorsports. Rear trunk floor, Jack posts and supports replaced. Driver side sail panel replaced, left and right door jams replaced. Body was stripped down to bare metal. All-metal body filler was used on all seams. Car was painted and straightened by Lonnie Hensley of Key West. All gaps are perfect. PPG two step paint with 7 mils of clear coat. Rear wheel wells have been slightly stretched, not rolled or cut. Rust bullet and Por15 were used through out restoration. Car has fiberglass rockers. No hell hole problems ever. Battery support and tray have been replaced at one time. All worn or damaged rubber seals have been replaced. New windshield. New carpet. Car could use a front bumper top(small rip and wavy), Lower windshield chrome ( somebody scratched and sanded it) Dash top is cracked. A/C: DPD system using a Sanden 505 compressor all new hoses. Converted to 134A . This car has no heat and all A/C lines and electrical have been ran through the passenger side longitudinal instead of cutting holes. BRAKES: All new Zimmerman rotors Remanufactured front calipers, red ceramic coated Rebuilt rear calipers, red ceramic coated Porterfield R4-S brakes pads Stainless wrapped Teflon brake lines DOT Speed bleeders ATE Super Blue brake fluid 19 mm master cylinder Rebuilt pedal cluster with bronze bushings SUSPENDSION: 4 New Bilstein gas shocks 180lbs. Progressive rear springs 22mm Weltmeister front sway bar Kumho Ecsta 205/50/15 on Panasport 15x6 rims Lowered and set up by KMW motorsports Turbo tie rods TRANSMISSION: All new shift bushings All new seals New 1st gear kit installed by KMW motorsports New clutch New clutch cable Swepco 201 GAUGES/ ELECTRICAL: Dakota digital head temperature gauge VDO oil pressure gauge VDO oil temperature gauge VDO volt meter gauge Optima battery Pilot driving lights H4 headlights Kill switch with safety cover (cut off ignition and fuel pump) Sony explode CD withMp3 port ENGINE: Stock 2.0 liter with original pistons Heads remanufactured and upgraded by Len Hoffman at HAM Inc. Lower end rebuilt by Kevin Wheeler at KMW Motorsports Rebuilt Italian Weber, Dual 40 IDF New throttle cable Raby Mallory Unilite distributor CB proformance fuel pump CFR stainless fuel line CB crank case breather Clewitt engineering spark plug wires Sainless steel heat exchangers Bursch exhaust 1.7 rocker arms, swivel feet adjusters, and Raby billet shims included but not installed Call Steve 305-587-4169 |
southernmost914 |
Sep 2 2009, 05:56 PM
southernmost914 |
Sep 2 2009, 06:00 PM
seebobgo |
Sep 2 2009, 07:46 PM
Member Group: Members Posts: 384 Joined: 14-December 05 From: Millersville, Maryland Member No.: 5,273 Region Association: MidAtlantic Region |
Sweet, and that's the cleanest windshield I have ever seen. Good luck with the sale (IMG:style_emoticons/default/beerchug.gif)
Tom_T |
Sep 3 2009, 10:52 AM
Willow Green was a 71-72 color.......so is this a non-OE color change or a special order paint when new? (IMG:style_emoticons/default/confused24.gif)
If not the original color, then what was? (IMG:style_emoticons/default/confused24.gif) |
southernmost914 |
Sep 3 2009, 11:47 AM
Willow Green was a 71-72 color.......so is this a non-OE color change or a special order paint when new? (IMG:style_emoticons/default/confused24.gif) If not the original color, then what was? (IMG:style_emoticons/default/confused24.gif) Original color was L64K Zambezi. |
southernmost914 |
Sep 3 2009, 12:02 PM
Price reduction $12500.00
Ferg |
Sep 3 2009, 12:20 PM
914 Guru Group: Members Posts: 5,948 Joined: 8-January 03 From: Boulder CO Member No.: 116 Region Association: None |
(IMG:style_emoticons/default/pray.gif) nice car!
southernmost914 |
Sep 8 2009, 02:34 PM
Price reduction! $11,500.00.
tat2dphreak |
Sep 8 2009, 03:39 PM
it's a very clean looking car! best of luck! it should make someone a VERY nice, completed car!
southernmost914 |
Sep 8 2009, 06:48 PM
southernmost914 |
Sep 8 2009, 06:49 PM
southernmost914 |
Sep 14 2009, 03:34 PM
Evolution custom car cover included.
southernmost914 |
Sep 16 2009, 03:50 PM
Lo-Fi Version | Time is now: 27th May 2024 - 09:01 PM |
