550 Spyder reproduction, Not a kit. 914-based copy of Porsche 550 #063 in MAS |
Bones |
Sep 18 2009, 08:42 PM
Newbie Group: Members Posts: 10 Joined: 24-February 08 From: Hardwick, MA Member No.: 8,744 Region Association: North East States |
550 Spyder Project This is not a kit. It is a one-of-a-kind copy of 550 Spyder #063 body on a tubular space frame with modified Porsche 914 mechanicals. It is not finished.
After 20 years and thousands of hours, I am "running out of gas" and time on this labor of love. This is a very special car for the right person. It is more than 95% complete, but needs someone with good mechanical skills who would enjoy a challenge that would produce a very fast, sturdy and reliable car. I did not get a title for the donor car, since it was not required at the time I bought it. I think this may be an obstacle here in Massachusetts. Maybe there is a procedure for it, but I have no more time or energy for it. OR: Maybe someone wants a great track car and doesn't need a title. No more welding is needed. The only major parts not included are a windshield and an exhaust system. I don't think this could be duplicated for less than $30K. If you would like pictures and specifications, please email me at jimpavao@gct21.net. Power: Porsche 914 2.0 engine (GA) 2056cc three-angle valve cut mild head work Webcam performance hydraulic lifter cam 911 fan, alternator, voltage regulator & FAT shroud Moeling high capacity oil pump Weber IDF 40 carbs, w/32 mm venturies and correct jets external oil cooler (your choice of two) 914 transaxle rebuilt with closer ratios (AA, GA, N, Y, ZA) Chassis: Tubular steel triangulated frame 914 steering rack w/930 tie rods 5-lug steel Porsche wheels (two sets) Unequal A-arms front & rear Adjustable anti-sway bars and Carrera shocks All brake and hydraulic clutch lines Throttle cable & linkage, pedal to carbs Hand brake lever and lines All calipers (914) Full, braced, removable roll bar Fuel cell, electric pump, all lines tank to carbs Body: Full fiberglass body, copied from 1956 low-tail 550 completely removable from frame Door hardware (hinge plates, hinges, latches, interior handles/linkage) Aluminum floors Original Porsche 356 engine grilles Repro early VW covered headlights Round taillights Wiring harness Fiberglass seat shells (copied from original Spyder aluminum ones) Needs: Install valve gear, clutch Assembly Body finishing (currently grey gel-coat) Windshield Exhaust system Title, if you register it. (Have sales slips from body, frame, donor car.) |
Lo-Fi Version | Time is now: 15th May 2024 - 06:53 AM |
