Introducing "Dirty Penny" - Former $2010[$2012] GRM Project, Running. Driving. Boosting. FUN! |
jpnovak |
Sep 22 2009, 10:09 PM
They call me "Nanoman" Group: Members Posts: 231 Joined: 26-August 09 From: Austin TX Member No.: 10,736 Region Association: Southwest Region |
I wanted to introduce myself as a new member to the World. I am new to the 914 but not new to air-cooled. I have two 1971 911s; a T - soft-window targa and an ST-replica track car. I am sure I have seen many of you on Pelican. With the 911 I have done it all, rust repair, paint, engines, transmissions and chassis setup. I felt it was time for something new.
Introducing my new project. "Dirty Penny" Penny is a 1975 Porsche 914. She has been sitting unattended for a while. I found her at a friends house under the old oak tree. Penny is wearing copper metallic paint and had a white interior. Penny arrived without a heart. I am going to give her new life. Penny will be built as a Grassroots Motorsports $2010 Challenge car. For those not familiar that means you have $2010 to build a car where it competes in a concours, drag race and autocross. The prize? Notoriety in GRM and ridicule from those who already think you are nuts and cheap. My wife doesn't affectionately call me Fred Sanford for nothing. (IMG:style_emoticons/default/smile.gif) Here are a few pictures of Penny being unearthed from her previous home. The TX sun has not been kind to the paint, nor the interior. However, the dry climate has left her remarkably rust free. There is rust in the Hell Hole that has been previously cut out yet never welded back in. Rot is almost non-existent. (IMG:http://www.914world.com/bbs2/uploads_offsite/forums.pelicanparts.com-179-1309889178.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/forums.pelicanparts.com-179-1309889179.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/forums.pelicanparts.com-179-1309889179.3.jpg) How much money I have left to spend on the project. (IMG:http://www.914world.com/bbs2/uploads_offsite/forums.pelicanparts.com-179-1309889180.4.jpg) The plan is simple to do well at the Challenge. Get a car that handles well. Strip the weight out of it. give it some extra HP. Let's see... A 914 handles well. they are already pretty light. but the Type IV doesn't lend itself to high HP without major $$$. A bit of late night ebay browsing and I came across a JDM Subaru EJ20G drivetrain. Yes, that's what I need. ITs still a flat-4 - yet has to be water cooled and makes 140+ HP/L in stock trim. I like it. The vendor was in Dallas which means reduced shipping costs. Yep, that's the rule. you must account for ALL purchases. The new heart and soul... Oh yeah it will have soul! (IMG:http://www.914world.com/bbs2/uploads_offsite/forums.pelicanparts.com-179-1309889180.5.jpg) to be honest, work has been crazy and I have 13 months to build the car. Progress won't be fast. I am excited to make this go forward. The challenge of swapping the entire drivetrain begins with connections. The engine mounts are easy. Trying to get the shift linkage, clutch linkage and throttle cable done on the cheap is not so easy. I know there is a wealth of information on this site. Thanks to all those who have traveled this road before me. Until the next update... Now I have to figure out how to post images on this site rather than link external. |
jpnovak |
Oct 7 2011, 03:34 PM
Disappointment. What can I say but... Disappointment.
The morning started off great. Car started right up. I was able to solve my idle problems by reversing two wires and generally the car was running well. I went through the Concours section early and there was the rest of the day to put down a good AX time. However, before I took a run I had to plug the laptop into the car and actually drive it some. I had an unknown EFI map and the last thing I wanted to do was blow the motor by running lean on boost. Bad things happen when lean on boost.. So I plugged in the computer and went for a drive down the backroad that leads to the entrance to the raceway. I was just driving back and forth easily working my way up through the revs making sure everything was going well. Once I was satisfied that the AFRs were safe I turned on the camera and fillmed a few passes. https://www.youtube.com/watch?v=7o2Q7XKKoCg The car was running great. Pulling hard and its definitely quick. I was starting to think of how fast an AX run I could get and then the shifter cable broke. I can fix that. However, upon rev down, the motor knocked right before It reached idle. It was not a good knocking sound but it was quick and then gone. I shut the car off since i had to manually put the car in gear. It fired right away and I started driving back into the paddock area. As I was coming through the last set of gates the car knocked again and then shut off. the starter would not turn the motor. I decided to let it cool down before doing anything else. Besides, I had to fix the shifter before making a run. I located a team with a welder and a generator and quickly had the car shifting. the motor would still not turn over. Not good. Once it was cool enough I pulled the plugs. No sign of water. This means its not a blown headgasket. The oil looks clean but I have not pulled the filter. The motor is still locked. It is so locked that I broke a 22mm socket trying to free it. Done. Kaput. Finsihed. Not to DNF was the only goal I set for the event. I did not even meet that one. And so... tonight I will have a good time and tomorrow I will start the long drive home. Many thanks to all the teams that offer help. many thanks to Brad(?) from DIY Autotune that lent me his sun canopy so I could lay under the car and try to revive her. Many thanks to the GRM staffers who put on a great event. I will be back. And I have a full year to sort Penny. She will return and she will pissed next year. Watch out! I really learned how things work at the Challenge. |
Lo-Fi Version | Time is now: 30th April 2024 - 11:51 AM |
