Found two splices at the relay board, Why would this be done? |
scrz914 |
Sep 27 2009, 10:12 PM
Member Group: Members Posts: 397 Joined: 21-April 04 From: Santa Cruz, CA Member No.: 1,960 Region Association: Central California |
So as I reconstruct my FI system I'm finding all sorts of weirdness. I found splices at the relay board.
The first splice is from pin 1 (big yellow wire) from the main harness to pin 6 (other big yellow wire) on the connector from the engine. From what I"ve read, this wire has to do with the starter solenoid? Why would someone jump the relay board except maybe there's a bad relay? Then why not just buy a new relay. The second splice is from the black/red (fuel pump?)wire on the main harness to the ground wire from the FI Harness (four prong connector to the relay board). Whatever the problems were, would it be best to start trying new relays without the jumps? New relay board? I want to get this back to a '73 stock FI system. What are most common reasons to do these relay jumps? Attached image(s) |
ClayPerrine |
Sep 28 2009, 01:14 AM
Life's been good to me so far..... Group: Admin Posts: 15,470 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
The big yellow wire is for the starter. It just passes through the relay board, with some branches to feed fuel injection stuff. Disconnect the added jumper wire and see if it cranks. If it does, remove it. The DAPO was probably having a hot start problem and was using a shotgun diagnosis to fix it.
The fuel pump wiring change was probably done to accommodate carbs. The computer turns the fuel pump on in a D-Jet system. So if you eliminate the computer, then the fuel pump won't run. What you describe would activate the fuel pump when the key was on. If you are going back to stock FI, then just remove the DAPO change. Good luck! |
scrz914 |
Sep 28 2009, 10:18 AM
Thanks Clay. That does make sense. I do believe that this car did have carbs at one time and that a PO threw together a patchwork of FI components.
Lo-Fi Version | Time is now: 18th May 2024 - 10:07 PM |
