going 5 lug, what should I expect? |
tat2dphreak |
Sep 28 2009, 09:33 AM
ok, I've decided to go 5-lug (phone dials). this will be on a stock-body car, but I might roll the fenders a little(<1") if the rims need it.
I plan to re-drill the rear hubs or buy some that are already drilled. on the front I hear often how bad adapters are, but would they work as a stop-gap until I find a 911 front end? I know 74+ front ends are what we are supposed to look for, is there a specific model to avoid? what is the going price for a 911 front end? I was basically thinking of getting just the strut tower and calipers. but do I need the whole steering rack? will my -4 ball joints, tie rod ends, shocks(koni yellow), etc bolt up? these are new, so I 'd hate to replace them if they are still usable on a 911 front end. |
jmill |
Sep 28 2009, 09:51 AM
Why don't you just get the re-drilled front rotors from Eric? They would be much better than adapters. As far as 911 stuff you only need the struts (+inserts), hubs and brakes. All the rest of the stuff from your 914 will fit. You'll have to decide if you want to go 3" or 3.5". I paid $700 for a complete 3.5" front end with the swaybar and aluminum cross member. It's way cheaper to go with Eric's rotors. The bigger vented rotors and brakes are the only reason to go with the 911 parts. You'll have to decide if it's worth it. Billet hubs are another way to go if you have a bunch of cash wrapped up in 914 inserts and you want the bigger brakes.
JFJ914 |
Sep 28 2009, 09:57 AM
Senior Member Group: Benefactors Posts: 813 Joined: 13-June 03 From: Alpharetta, GA Member No.: 814 Region Association: South East States |
ok, I've decided to go 5-lug (phone dials). this will be on a stock-body car, but I might roll the fenders a little(<1") if the rims need it. I plan to re-drill the rear hubs or buy some that are already drilled. on the front I hear often how bad adapters are, but would they work as a stop-gap until I find a 911 front end? Depends on the adapter. The cheap ones for Bugs may kill you! I don't know of any good ones, but I would look for something like the H&R 5X5 bolt on spacers, they are TUV approved. They will also increase the track so check to see if the wheels will still fit I know 74+ front ends are what we are supposed to look for, is there a specific model to avoid? No, 69 to 89? will fit what is the going price for a 911 front end? Don't know I was basically thinking of getting just the strut tower and calipers. but do I need the whole steering rack? Struts only are fine, just make sure you get everything connected to them. Steering racks are the same, if you change it, make sure you use the 914 input shaft. will my -4 ball joints, Yes as long as the strut you get is compatible. Pre 73's use a through bolt, 73 up use a wedge pin. Either way the both ball joints fit any A arm. tie rod ends, Yes shocks(koni yellow), I think so, I'm interested in the answer myself etc bolt up? these are new, so I 'd hate to replace them if they are still usable on a 911 front end. |
cobra94563 |
Sep 28 2009, 10:28 AM
Chris Group: Members Posts: 341 Joined: 1-March 05 From: San Francisco Member No.: 3,696 |
If you have a good front end, another option is to just buy the 5 lug hubs for the front (keep your front suspension). Made/sold by Brad on the club site. But 3 yrs ago, I paid $600 for a complete front suspension, incl aluminum cross member. I thought it was a good price for something ready to go.
Eric_Shea |
Sep 28 2009, 11:17 AM
QUOTE I know 74+ front ends are what we are supposed to look for, is there a specific model to avoid? what is the going price for a 911 front end? For a standard narrow bodied 4 cylinder car I would not look for the 74+ unit. I would look for 911T struts loaded with M-Calipers and Vented rotors. 1970 through 1973 would be perfect. You get: Boge struts that will accept any aftermarket insert Vented rotors that never fail on a 914 M-Calipers. You could also bolt on our Brembo upgrades in the future. Keep the A-Arms for proper 914 spring rates Late model ball joint recepticals I've seen them for $150-300 for the struts. I think it's a perfect match for a narrow car. Porsche did too which is why it's on every stock 914-6. You could go with the later units (with the 3.5" spacing and A-Calipers) if you plan this to be a wide body car with more hp later. |
jmill |
Sep 28 2009, 03:13 PM
shocks(koni yellow), I think so, I'm interested in the answer myself etc bolt up? these are new, so I 'd hate to replace them if they are still usable on a 911 front end. 914 inserts don't fit in 911 struts. You'll have to change those out. Thats one of the reasons the billet hubs are nice. You can keep your 914 struts and run the 911 vented rotor. |
jcd914 |
Sep 28 2009, 03:47 PM
It depends on the 911 struts you get.
I put 71 911T struts on my 914 and they work fine with my Koni Yellow Gas Sport inserts. All the Boge struts I have come across are the same dimensionally although some have different gland nuts so you might have to hunt down a gland nut that fits your insert and the strut. With Koni or Bilstien struts are limited to Koni or Bilstien inserts. Jim |
tat2dphreak |
Sep 28 2009, 03:51 PM
if it's $600 for a 911 front end then I'll have to consider the 5 lug hubs an option. but for that 600 I would think I'd get the calipers too, and maybe a usable set of inserts, then I could sell the 914 koni yellows and stock (rebuilt by eric) calipers to help fund it. the 550 for just hubs is a little steep
why will 74+ struts not fit under the narrow cars? this is the first time I've heard that. I really don't want to go flares on this one any time soon. and the hp will be under 150 for a long time I'm thinking. that said, the 70-73 setup sounds ideal, especially if there's a brake upgrade option later... this may have to be back-burner until next year, I want to drive the car, now, not just find more parts, and spend more cash. (IMG:style_emoticons/default/biggrin.gif) |
underthetire |
Sep 28 2009, 03:57 PM
Don't forget rear wheel bearings while your doing it. There are 2 types of wheel adapters really. Cast aluminum ones that will probably come apart at the worst time, and actual billet hub-centric ones. I am using the later as my stop gap. I am running later dials, 16X7 all the way around. I needed the spacer anyway. The adapters are 1" thick. I have had ZERO problems so far, although you won't be able to autocross it.
tat2dphreak |
Sep 28 2009, 04:02 PM
ok, where do you get these usable adapters? I'm not worried about auto-x if I really wanted to I could swap back to 4-lug for auto-x with adapters...
but I'm not dropping $500(AA) for adapters when that will be most of what a conversion will cost... |
underthetire |
Sep 28 2009, 04:12 PM
I wouldn't use the adapters in the rear anyway, no hub-centric on the car. I got mine here on the site for like 100 bucks. What kind of time frame are you doing it? As soon as I get new front rotors and re-drill them i'll be getting rid of them. Or put a WTB on the classifieds.
TravisNeff |
Sep 28 2009, 04:18 PM
Keep in mind when buying the struts you know what conditions the parts are in. If not, expect to replace or turn the rotors, rebuild the calipers, new pads and new wheel bearings and soft brake lines - don't forget the lug nuts too.
tat2dphreak |
Sep 28 2009, 04:25 PM
I'm keeping an eye open, but this isn't a priority... lmk if you sell yours before I do the conversion.
my fronts are the late-style(hub centric) now, is losing the hubcentric ability a big deal? it seems like it would be, but I dunno. I know what you mean about the rears... I was planning on redrilling or buying eric's rear hubs. these are the early phone dials I'm going to be using, I believe. not sure how much spacer is required to make them "work", vs how much is "recommended" to look right... QUOTE Keep in mind when buying the struts you know what conditions the parts are in. If not, expect to replace or turn the rotors, rebuild the calipers, new pads and new wheel bearings and soft brake lines - don't forget the lug nuts too. yea, I'm keeping that +new bearings, new a-arm bushings and rear bearings all in mind. I may rebuild the calipers myself, but was planning on new rotors or at least turning them if they are in good enough shape. the brake lines are all new already, but I hadn't thought of the lug nuts as a big expense, I'll have to take a look. |
underthetire |
Sep 28 2009, 04:36 PM
If they are the early (pre 87?) offset, I don't know. 6" might be ok with adapters, don't think the 7s would work. All I have to go on from personal experience is the later 16X7's.
jmill |
Sep 28 2009, 04:40 PM
why will 74+ struts not fit under the narrow cars? this is the first time I've heard that. I really don't want to go flares on this one any time soon. and the hp will be under 150 for a long time I'm thinking. They'll fit. I think what Eric meant was that he didn't see a need to go with the 3.5" spacing and A caliper on a narrow body car. |
tat2dphreak |
Sep 28 2009, 04:42 PM
ok, that makes sense. I was told 74+ because of so many caliper options. but I think anything vents is made of pure win for the type of hp I'll be running.
Spoke |
Sep 28 2009, 04:44 PM
If you hold your breath long enough, maybe you'll find a deal like I got for $450 on ebay:
911 Carrera front end includes a-arms, torsion bars, aluminum crossmember (with horn attached), sway bar, struts, vented rotors, 3.5in calipers, tie rods, and steering rack. Seller thought it was from a mid to late 80's 911. Rear end includes swing arms, complete axles w/inner/outer CVs, 4-to-5 lug converted hub and rotor, 914-4 caliper. Attached image(s) |
tat2dphreak |
Sep 28 2009, 07:59 PM
nice score, grats!!
jaxdream |
Sep 28 2009, 10:15 PM
Senior Member Group: Members Posts: 974 Joined: 8-July 08 From: North Central Tennessee Member No.: 9,270 Region Association: South East States |
Phone dials come in different flavors , I have a set of 6J X 15 36ET ( offset )Porsche part # 911-361-023-46 no need for spacers or adapters . HW Gunner had a set of black powder coated IIRC 6J X 15 for sale at one time on e-bay , maybe sold.
Phones can be found from 944 early offset -23 , late offset 52.3 , most of them being 7J X 15 , later 16 . For a narrow body , which I have , the 6J X 15 Phones are the way to go , no spacer , adapetrs if you change to 5 lug .You could get a set of fuchs , but not as cheap as phones, cookie cutters are cheap also , but I haven't done any research on them , BTW I have a set of 944 7J X15 52.3ET with 215 tires , I tried them out on a 5 lug mockup with 21 mm spacers , common on 944's, they fit without any rubbing but with only a finger thickness of room between the outside fender and tire,about the same on inner fenderwell this was driver's side, so..a thinner tire width on the 7 wide would yield more clearence I would hazard a guess. It all depends on the money you want to spend on 5 lug conversion, it could be done cheaper if you watch for deals , takes a little longer , than jumping on it with a dead line. Good Hunting... Jaxdream |
tat2dphreak |
Sep 28 2009, 10:42 PM
yea I'm taking my time, I just wanted to know what to look for. I'm hoping for a deal, maybe someone even wants to trade for a 1.8 and a Djet setup (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/av-943.gif)
Lo-Fi Version | Time is now: 17th May 2024 - 09:44 AM |
