Trans leak at the linkage shaft, Paging Dr. Evel, Please call ER stat |
URY914 |
Oct 1 2009, 07:42 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,980 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
But to replace the seal I'll need to remove the roll pin and pull the shaft out.
tradisrad |
Oct 1 2009, 07:51 PM
I vaguely remember replacing the o-ring. I dont recall having to drive out any roll pin either. Sorry I did not have as complete of an answer as the Dr. did, but I've only done it once...
URY914 |
Oct 1 2009, 08:03 PM
The Dr. is probably busy in an O.R. and can't reply right now.
URY914 |
Oct 1 2009, 08:27 PM
Dr Evil |
Oct 1 2009, 08:32 PM
Send me your transmission! Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
Yes, remove the INNER pin so that when you reinsert your rod it goes with the seal instead of against it.
URY914 |
Oct 1 2009, 08:54 PM
OK but this will have to wait till Sat. morning. Thanks for all your help.
BTW, is "reinsert your rod" a medical term? (IMG:style_emoticons/default/biggrin.gif) |
maf914 |
Oct 2 2009, 12:30 PM
Paul,
Is that a bronze shift rod bushing in the console? If so, does it work okay? How is the fit on the shift rod? Snug or loose? |
ericread |
Oct 2 2009, 01:54 PM
The Viper Blue 914 Group: Members Posts: 2,177 Joined: 7-December 07 From: Irvine, CA (The OC) Member No.: 8,432 Region Association: Southern California |
Oct 2 2009, 02:24 PM
Custom Member Group: Members Posts: 24,585 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Paul,
When you are ready to get the roll pin out, support the forked piece very well so you dont stress out the aluminum console while banging. Also, while its out and simple, flip the bronze bushing around...its gives you a bit more clearance for 5th gear... Rich |
URY914 |
Oct 2 2009, 02:31 PM
The bushing was installed by the previous owner. I didn't even know it wasn't plastic.
URY914 |
Oct 2 2009, 02:32 PM
Paul, When you are ready to get the roll pin out, support the forked piece very well so you dont stress out the aluminum console while banging. Also, while its out and simple, flip the bronze bushing around...its gives you a bit more clearance for 5th gear... Rich You mean put the flange on the inside of the console? It is put in with JB Weld it look like. |
Oct 2 2009, 02:38 PM
Mine was all fine until I rebuilt and readjusted the shifter forks...then it hit.
If yours is in with JBWeld then leave it... If you ever have a problem with getting into 5th...that is the issue to look at first.. It could be from the position of the engine/tranny....it could be the shifter adjustment up front... Its really slight, but you just cant get all the way into fifth..the piece that attaches to the end of the shift rod hits that bushing...just a smidge. Rich |
URY914 |
Oct 3 2009, 07:02 PM
Thanks Mike but I ordered the seal from Pelican last night and it'll be here Tuesday. I've already drained the rest of the fluid. I got the seal in the mail today from Pelican. Three days early!! Who would have thunk it??? (IMG:style_emoticons/default/biggrin.gif) I should get o-ring on Monday. |
URY914 |
Oct 3 2009, 07:06 PM
I drove the roll pin out this morning. I tapped it on one side than the other a few times to get it loose than drove it all the way out. Here are the parts laid out, w/o the O-ring.
The piece on the lower right is the piece that came out with the fluid. It can't be good. (IMG:style_emoticons/default/sad.gif) Getting the old seal out was more of a pain than getting the pin out. Attached image(s) |
SlingShot |
Oct 12 2009, 12:25 PM
Newbie Group: Members Posts: 1 Joined: 15-September 09 From: Prescott AZ Member No.: 10,808 Region Association: None |
Similar Problem I'm having on a 70 914-6. It has the same leak at the shift selector seal. I replaced the seal, and it still leaks. There is a gap between the brass bushing and seal, so I placed an O ring there and that helped the problem, but still leaks. The shaft has some play inside of the brass bushing, but I wouldn't consider it exsesive. Any thought would be appreciated. Thanks, Chris
Lo-Fi Version | Time is now: 3rd June 2024 - 02:52 AM |
