| brant |
Sep 30 2009, 10:33 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,183 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains
my bet is that a pertronix for a Djet, or any 4 cylinder VW distributor would work
the collar or donut that goes over the distributor shaft (under the rotor) is damaged on mine the electronic receiver on mine is good... just the collar is damaged. did anyone burn out their pertronix and would be willing to help me get mine back on the road. I know this isn't the right place for a classified sorry in advance.. its a weird request and I won't be offended if its moved brant |
| stugray |
Sep 30 2009, 10:46 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
my bet is that a pertronix for a Djet, or any 4 cylinder VW distributor would work the collar or donut that goes over the distributor shaft (under the rotor) is damaged on mine the electronic receiver on mine is good... just the collar is damaged. did anyone burn out their pertronix and would be willing to help me get mine back on the road. I know this isn't the right place for a classified sorry in advance.. its a weird request and I won't be offended if its moved brant Brant, I have a couple of what appear to be stock distributors from the stuff I showed you from the 914 purchase. You are welcome to come have a look. Stu |
| brant |
Sep 30 2009, 10:53 PM
my bet is that a pertronix for a Djet, or any 4 cylinder VW distributor would work the collar or donut that goes over the distributor shaft (under the rotor) is damaged on mine the electronic receiver on mine is good... just the collar is damaged. did anyone burn out their pertronix and would be willing to help me get mine back on the road. I know this isn't the right place for a classified sorry in advance.. its a weird request and I won't be offended if its moved brant Brant, I have a couple of what appear to be stock distributors from the stuff I showed you from the 914 purchase. You are welcome to come have a look. Stu Stu, thanks a ton for the offer these little collars are unique to the pertronix (points replacements) there is always a chance somebody removed your points and installed a pertronix.. but if you find a full pertronix in one of your spares, you should really keep both parts of it to use yourself. I just need to find someone that burned one up.. I have the common failure part and need the extra that most failures throw away hey.. you going out to the enduro this weekend with your brother? stop by and say hi out there... about 4-5 914's will be there (I think most of them 4cylinders) how is the fish tank doing? brant |
| Sleepin |
Sep 30 2009, 10:57 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,647 Joined: 20-November 07 From: Grand Junction, Co. Member No.: 8,357 Region Association: Rocky Mountains |
I wish I knew you were up. Give me a call if you can. (IMG:style_emoticons/default/biggrin.gif)
| stugray |
Sep 30 2009, 11:16 PM
my bet is that a pertronix for a Djet, or any 4 cylinder VW distributor would work the collar or donut that goes over the distributor shaft (under the rotor) is damaged on mine the electronic receiver on mine is good... just the collar is damaged. did anyone burn out their pertronix and would be willing to help me get mine back on the road. I know this isn't the right place for a classified sorry in advance.. its a weird request and I won't be offended if its moved brant Brant, I have a couple of what appear to be stock distributors from the stuff I showed you from the 914 purchase. You are welcome to come have a look. Stu Stu, thanks a ton for the offer these little collars are unique to the pertronix (points replacements) there is always a chance somebody removed your points and installed a pertronix.. but if you find a full pertronix in one of your spares, you should really keep both parts of it to use yourself. I just need to find someone that burned one up.. I have the common failure part and need the extra that most failures throw away hey.. you going out to the enduro this weekend with your brother? stop by and say hi out there... about 4-5 914's will be there (I think most of them 4cylinders) how is the fish tank doing? brant I looked at both spare distros & they are both 009s. The one in the car still has the vac advance, so no chance I have any of the pertronix. Sorry, thought it might have been a stock part you were looking for ( got vintage on the brain ) I am planning on making the race this weekend. I will definitely look for you. Stu |
| brant |
Sep 30 2009, 11:19 PM
my bet is that a pertronix for a Djet, or any 4 cylinder VW distributor would work the collar or donut that goes over the distributor shaft (under the rotor) is damaged on mine the electronic receiver on mine is good... just the collar is damaged. did anyone burn out their pertronix and would be willing to help me get mine back on the road. I know this isn't the right place for a classified sorry in advance.. its a weird request and I won't be offended if its moved brant Brant, I have a couple of what appear to be stock distributors from the stuff I showed you from the 914 purchase. You are welcome to come have a look. Stu Stu, thanks a ton for the offer these little collars are unique to the pertronix (points replacements) there is always a chance somebody removed your points and installed a pertronix.. but if you find a full pertronix in one of your spares, you should really keep both parts of it to use yourself. I just need to find someone that burned one up.. I have the common failure part and need the extra that most failures throw away hey.. you going out to the enduro this weekend with your brother? stop by and say hi out there... about 4-5 914's will be there (I think most of them 4cylinders) how is the fish tank doing? brant I looked at both spare distros & they are both 009s. The one in the car still has the vac advance, so no chance I have any of the pertronix. Sorry, thought it might have been a stock part you were looking for ( got vintage on the brain ) I am planning on making the race this weekend. I will definitely look for you. Stu Cool... thanks for looking Stu! definitely come by at the track this weekend! brant |
| RJMII |
Sep 30 2009, 11:41 PM
Jim McIntosh ![]() ![]() ![]() ![]() Group: Members Posts: 3,125 Joined: 11-September 07 From: Sandy, Utah Member No.: 8,112 Region Association: None |
Brant, I'll check my stash, too. I saw points in my box of parts, and not sure if it was because they got replaced or what...
but you're welcome to the parts you need if they are there. (I sure as heck won't need them! lol) |
| brant |
Sep 30 2009, 11:43 PM
Brant, I'll check my stash, too. I saw points in my box of parts, and not sure if it was because they got replaced or what... but you're welcome to the parts you need if they are there. (I sure as heck won't need them! lol) thats very kind of you seriously nice when is your next trip down south going to be ? we need to have a BBQ or something before the weather really turns thanks sir brant |
| RJMII |
Oct 1 2009, 12:39 AM
Brant, I'll check my stash, too. I saw points in my box of parts, and not sure if it was because they got replaced or what... but you're welcome to the parts you need if they are there. (I sure as heck won't need them! lol) thats very kind of you seriously nice when is your next trip down south going to be ? we need to have a BBQ or something before the weather really turns thanks sir brant I'm not sure when my next trip south will be, but the part will easily make it to you if I have it. That BBQ idea sounds nice, though. (IMG:style_emoticons/default/smile.gif) |
| SUNAB914 |
Oct 1 2009, 07:28 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 698 Joined: 29-December 08 From: Fredericksburg VA Member No.: 9,880 Region Association: South East States |
I think I have one if you still need it.
| Ferg |
Oct 1 2009, 08:46 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,948 Joined: 8-January 03 From: Boulder CO Member No.: 116 Region Association: None
Come over tonight after work, I burned up a pertronix years ago, have the whole system in it's box, you can take it all...
Silly, it was right under your nose (IMG:style_emoticons/default/biggrin.gif) Ferg |
| tat2dphreak |
Oct 1 2009, 09:10 AM
stoya, stoya, stoya ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region |
I have 2 009s with pertronix/compfire if you want one, lmk. the one for a stock(vac advance) dizzy is different but the 009 and 050 use the same one.
| brant |
Oct 1 2009, 09:50 AM
You guys are the best!
Thanks for the offers guys I think I have it covered thanks to the seller! But thanks a ton SUNAB914, and Wayne! Ferg, I'll see you at lunch... thanks a ton and the seller is really top notch too! JT on this site, sells parts Excellent customer service all the way through and he is going to help me out by replacing the collar! Thanks JT! brant |
Lo-Fi Version | Time is now: 2nd May 2026 - 04:05 AM |
