LE - WHAT SHOULD I LOOK FOR ? |
advtracing |
Oct 2 2009, 05:26 PM
Member Group: Members Posts: 73 Joined: 27-September 09 From: New Zealand Member No.: 10,853 Region Association: None |
HI GUYS,
Newbie here again , i have the 914 home and will take some more photos today , but what colour would have been sprayed in to the dash area during production ? undercoat colour and top colour / Now i'll tell you why .... under the dash top is black ... but under the black when gently scraped away is lime yellow/green |
Todd Enlund |
Oct 2 2009, 05:28 PM
Resident Photoshop Guru Group: Members Posts: 3,251 Joined: 24-August 07 From: Laurelhurst (Portland), Oregon Member No.: 8,032 Region Association: Pacific Northwest |
HI GUYS, Newbie here again , i have the 914 home and will take some more photos today , but what colour would have been sprayed in to the dash area during production ? undercoat colour and top colour / Now i'll tell you why .... under the dash top is black ... but under the black when gently scraped away is lime yellow/green I learned that during production, the dash was painted whatever color was handy. It had no relation to the color of the body. |
advtracing |
Oct 2 2009, 05:30 PM
HI GUYS, Newbie here again , i have the 914 home and will take some more photos today , but what colour would have been sprayed in to the dash area during production ? undercoat colour and top colour / Now i'll tell you why .... under the dash top is black ... but under the black when gently scraped away is lime yellow/green I learned that during production, the dash was painted whatever color was handy. It had no relation to the color of the body. cheers |
SLITS |
Oct 2 2009, 05:36 PM
Get the vin and send it to Jeff Bowlsby or check his site for the range of vins. It has to be a '74.
JRust |
Oct 2 2009, 05:39 PM
914 Guru Group: Members Posts: 6,307 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
What to look for on an LE?
1st check the front spoiler/air damn. If it's an original LE airdamin it will be injection molded. meaning on each end there are 2 holes where they shot the injection in. Also it has 2 extra mounting tabs on the bottom about 1/3rd from each end. Most importantly the car will have these 2 tabs coming out for those to mount too. Also the OE LE air damn has a stamp in the middle on the backside with numbers. 2nd The targa bar vinyl doesn't exist. If there are no holes there & they haven't been filled that is another indication. 3rd It is loaded so it should have front & rear sways, 2.0 motor, fog lights, center console with gages. Rear window defrost was an addition. some had it some didn't. 4th Only wat to bee sure is to get a COA. Certificate of Authenticity from Porsche. It will list it as a LE Can Am car. My COA showed my engine number along with the vin, paint code & such. 5th Should have 4lug Mahle wheels. They would either be yellow or Pheonix red |
advtracing |
Oct 2 2009, 06:11 PM
Get the vin and send it to Jeff Bowlsby or check his site for the range of vins. It has to be a '74. i have listed the vin in the data base, it fall in the LE area and the car is a 74, it does have the front spolier with centre gap and as noted in a earlyer thread of mine and green negitive script. colour code is L80E . BUT it has targa bar vinyl with trim and fuchs . (IMG:style_emoticons/default/rolleyes.gif) |
SLITS |
Oct 2 2009, 06:19 PM
Vinyl on the sail panels with the brightwork strip running along the bottom?
After 35 years and who knows how many owners, things could have been changed. And Porsche supposedly never imported cars to the "Land Down Under" area. |
JRust |
Oct 2 2009, 06:56 PM
Get the vin and send it to Jeff Bowlsby or check his site for the range of vins. It has to be a '74. i have listed the vin in the data base, it fall in the LE area and the car is a 74, it does have the front spolier with centre gap and as noted in a earlyer thread of mine and green negitive script. colour code is L80E . BUT it has targa bar vinyl with trim and fuchs . (IMG:style_emoticons/default/rolleyes.gif) The Grasshopper LE is a myth anyway. There is nowhere Porsche has that color code as a Can Am option from what I understand. I think there may be a possibility that a few had Fuchs on them. None of them had Vinyl trim but that could have been added. More likely they tried to make it look like an LE than the other way around (IMG:style_emoticons/default/confused24.gif) |
JeffBowlsby |
Oct 2 2009, 07:01 PM
914 Wiring Harnesses Group: Members Posts: 8,507 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
May be an interesting find...I looked in the VIN list could not locate it. Can you post your VIN and a few photos here?
advtracing |
Oct 2 2009, 09:47 PM
May be an interesting find...I looked in the VIN list could not locate it. Can you post your VIN and a few photos here? Get the vin and send it to Jeff Bowlsby or check his site for the range of vins. It has to be a '74. i have listed the vin in the data base, it fall in the LE area and the car is a 74, it does have the front spolier with centre gap and as noted in a earlyer thread of mine and green negitive script. colour code is L80E . BUT it has targa bar vinyl with trim and fuchs . (IMG:style_emoticons/default/rolleyes.gif) check this link for photos of the vin etc,,, http://s359.photobucket.com/albums/oo33/ad...mview=slideshow and the under dash paint color in the photo attached . The garage is abit chocker with parts and cars , so once i have sorted and moved the parts to storage No. 2 i'll get better all over photos Attached image(s) |
championgt1 |
Oct 2 2009, 10:13 PM
Don't embarrass me Filmore! Group: Members Posts: 2,680 Joined: 3-January 07 From: Tacoma, Washington Member No.: 7,420 Region Association: Pacific Northwest |
Here is the underside of my dash. Factory Olympic blue car.
advtracing |
Oct 2 2009, 10:39 PM
JeffBowlsby |
Oct 3 2009, 10:15 AM
Actually your cars VIN falls outside the VIN range of LE cars, the lst VIN is 16764. See teh note on the LE Registry for VIN 16764. It is possible that your car may have the LE paint scheme which is code U2V9 for a Creamsicle, some of the cars right after the LE VINs had the LE paint scheme only, but not the equipment. Getting a COA would be the only way to verify.
Oddly, I see orange paint in unusual places for an L80E car - on the back wall of the inside of the cabin, under the rocker covers. (IMG:style_emoticons/default/confused24.gif) Get the vin and send it to Jeff Bowlsby or check his site for the range of vins. It has to be a '74. i have listed the vin in the data base, it fall in the LE area and the car is a 74, it does have the front spolier with centre gap and as noted in a earlyer thread of mine and green negitive script. colour code is L80E . BUT it has targa bar vinyl with trim and fuchs . (IMG:style_emoticons/default/rolleyes.gif) |
advtracing |
Oct 3 2009, 01:21 PM
Here is the underside of my dash. Factory Olympic blue car. interesting , vw quirk i guess . With the 911's i have around this time it's always black undercoat with semi black top coat on the dash area's Hi, i belived the number was in the number range based on the vin data base details on this site were the back ground is yellow and LE numbers are shown before and after my listing , is this incorrect? |
Oct 3 2009, 01:44 PM
Hi, i belived the number was in the number range based on the vin data base details on this site were the back ground is yellow and LE numbers are shown before and after my listing , is this incorrect? Good question! When i coded the VIN database here on this site, i used Bowlsby's range numbers for the background coloring. Jeff, has the known to be good range for LE cars changed since i implemented the VIN database? (IMG:style_emoticons/default/idea.gif) Andy |
JeffBowlsby |
Oct 3 2009, 01:45 PM
I can see why you were led to belive that, but that colored info on this site's VIN index is not current. We only dioscovered a few months ago, from direct communtications with PCNA, that the first 914 LE VIN was 14348 and the last is 16764. The later VINs after 16374 shown on the registry have the correct paint code for a 914, but no the equipment. At least that is what PCNA is telling us that their factory records indicate.
http://bowlsby.net/914/CanAm/ This is the 914 LE website with the Registry which is current. Check out the 914 LE webpage on the site and review the 'Personal Porsche' information at the bottom of th e page...that may describe how your car came to look the way it does with the green stripe If you want to be certain, you will need to get a COA. |
advtracing |
Oct 3 2009, 02:37 PM
I can see why you were led to belive that, but that colored info on this site's VIN index is not current. We only dioscovered a few months ago, from direct communtications with PCNA, that the first 914 LE VIN was 14348 and the last is 16764. The later VINs after 16374 shown on the registry have the correct paint code for a 914, but no the equipment. At least that is what PCNA is telling us that their factory records indicate. http://bowlsby.net/914/CanAm/ This is the 914 LE website with the Registry which is current. Check out the 914 LE webpage on the site and review the 'Personal Porsche' information at the bottom of th e page...that may describe how your car came to look the way it does with the green stripe If you want to be certain, you will need to get a COA. Thnaks Jeff, that clears that up . I will obtain the coa in the next few months but i doubt that it will show an LE . i couldn't find ref to the green script on the link you provided , i'm guessing that it ref to dealerships installing them themselves? |
JeffBowlsby |
Oct 3 2009, 11:34 PM
There is not much on the 914 LE website about the white/green trim car...because it does not exist... (IMG:style_emoticons/default/biggrin.gif) Below is the letter from Porsche AG documenting that. Also something else I noticed about your green stripes...they are a dark green. Porsche only offered 1 color of green stripe, which was more of a lime green, as an aftermarklet accessory. See the color below, maybe your was a custom stripe a previous owner had made?
I can see why you were led to belive that, but that colored info on this site's VIN index is not current. We only dioscovered a few months ago, from direct communtications with PCNA, that the first 914 LE VIN was 14348 and the last is 16764. The later VINs after 16374 shown on the registry have the correct paint code for a 914, but no the equipment. At least that is what PCNA is telling us that their factory records indicate. http://bowlsby.net/914/CanAm/ This is the 914 LE website with the Registry which is current. Check out the 914 LE webpage on the site and review the 'Personal Porsche' information at the bottom of th e page...that may describe how your car came to look the way it does with the green stripe If you want to be certain, you will need to get a COA. Thnaks Jeff, that clears that up . I will obtain the coa in the next few months but i doubt that it will show an LE . i couldn't find ref to the green script on the link you provided , i'm guessing that it ref to dealerships installing them themselves? Attached thumbnail(s) Attached image(s) |
advtracing |
Oct 11 2009, 10:13 PM
Well just in , details off the porsche data base through porsche new zealand , she's a stocker..
Details are: model 914 year 1974 built 01/05/1974 colour light ivory B8V9 Del USA C02 options 567=windscreen tinted,compound glass, 570=additional seatcushion between seats (IMG:style_emoticons/default/hissyfit.gif) |
Lo-Fi Version | Time is now: 17th May 2024 - 08:17 AM |
