Another trick for you guy building high RPM sixes |
TimT |
Mar 13 2004, 08:49 PM
OK...8000 RPM plus...the engine needs some "oiling" help.
have the crank cross drilled... Its mentioned in BAs book... To compliment the cross drilled crank, you have to modify the center main bearing.. Made a fixture to hold a bearing (this can be reversed one end holds a 3.3 the other a different main) A finished bearing is in the fixture in this pic Attached image(s) |
Lo-Fi Version | Time is now: 18th May 2024 - 11:22 PM |
