QUOTE(tabs914 @ Oct 19 2009, 03:12 PM)
QUOTE(JamesM @ Oct 19 2009, 12:04 PM)
Here is some info...
http://www.ratwell.com/technical/HydraulicLifters.htmlEverything i can find on them says 1-2 turns past contact.
Been meaning to adjust mine as well, I have not touched them in the last 30,000+ miles of abuse.
How do you know if you have them... I just put in a '75 "AW" Bus engine in my '70 914 When I went to do the valves there was zero clearance on all them...
I know they are in mine because i requested that my engine builder put them in 10 years ago.
I knew a lot less then and did not want to mess with valve adjustments on my daily driver. 10 years later and i still have yet to touch the adjusters on that motor.
If you have no clue what is in your motor, look further down on that link under "identification". There is a difference in the pushrods used with the hydo lifters. I don't think the AW engine had them from the factory but i am guessing if you have 0 clearance on all your valves and it is not running like crap someone probably put them in.
here is another link with more bus/hydraulic lifter info
http://www.type2.com/library/engineg/hydral.htm
