QUOTE(Cire @ Oct 29 2009, 12:14 PM)
My goal is to totally remove the standard regular head light. Less weight, 1 less wire, less hassle... So just to get some street legal headlights in there would be great. = )
See? = )
They won't be street legal, they will be mounted too low. People that have done what you are trying to do have re-purposed the turn signal housings as headlight housings, using motorcycle headlights. That is the only way to get the height legal. its all custom work, at that point.
To remove the headlights would be more then 1 less wire. but to remove them would mean taking apart the entire forward wiring harness, or else you will be risking ground outs. Would be less work to remove the headlight motors and work up a cable pull system that uses small pneumatic struts (which has also been done and documented on this site.)
If your car is a street car at all, you are going to want legal headlights.
Zach
