Nürburg Nomad
Jun 29 2010, 03:06 AM
Mmmmmmm 15x7 cookies!
Sometimes I hide my cookies in the garage in favor of the incrementally lighter Fuchs, but I like both wheel styles equally!
914werke
Jun 20 2019, 09:59 AM
QUOTE(Mr.242 @ Jun 28 2010, 02:20 PM)
So, I am looking for two more Cookie Cutters. On the other board, I learned that there are different ones; 911 and 944's. Are there certain ones that only work on 914's? IF So, what is the part #'s? The two I have start with 911 #'s and were cast in '73. Thanks!!!
-Mark
I recently picked up a set of 6" cookies but when they showed up they were 2 diff. versions.
1st pair had a machined edge the other pair had completely flat lip. Both had the same part # 911.361.023.44
sixnotfour
Jun 20 2019, 10:23 AM
blast em and paint em or buy 2 more of your preference..
it seems like the early ones where full paint and around the 944era they got a brite lip,,like a diamond, with clear coat or 73 -77 has a ridge
take em to the wheel place across from eurotech. they can cnc em all to be fresh cut shiny
sixnotfour
Jun 20 2019, 11:02 AM
Mark Henry
Jun 20 2019, 11:42 AM
QUOTE(6freak @ Nov 30 2009, 05:42 PM)
QUOTE(Sleepin @ Nov 30 2009, 12:36 PM)
Sure they do
kind of a cool wheel but I myself would not call those Cookie cutters
they're not cookies, those are Audi "lockwasher" 14 x6" rims with the small 4 bolt pattern. Teenhulk has them on his '82 Audi coupe.
The wife's '72 has cookies. I have an extra set of fuchs, but if I put them on it will be harder to tell the twins apart.
gms
Jun 20 2019, 09:13 PM
I am doing up a set, black powder coated center, machine finished rim
gms
Jun 20 2019, 09:35 PM
did a set in semi-gloss black
Jun 20 2019, 10:29 PM
I really like them in black or metallic dark grey
914werke
Jun 20 2019, 10:40 PM
Glen are you turning them to clean them up or remove the small outer lip?
& do I understand that the diff versions also require diff. caps?
914werke
Jun 20 2019, 10:42 PM
QUOTE(1970-1914 @ Jun 20 2019, 09:29 PM)
falcor75
Jun 21 2019, 12:59 AM
Mine were silver with a black center. I've done a vintage gold plastidip center on them for now. Will eventually have them blasted and painted in the same way.
gms
Jun 21 2019, 08:06 AM
QUOTE(914werke @ Jun 20 2019, 11:40 PM)
Glenn are you turning them to clean them up or remove the small outer lip?
This style was originally machine finished so I was restoring them to factory finish for a 944 owner.
Unobtanium-inc
Jun 21 2019, 03:13 PM
Only cookie picture I could find.
yeahmag
Jun 22 2019, 09:32 PM
73-914
Jun 23 2019, 05:20 AM
My Cookies
sb914
Jun 23 2019, 06:15 AM
I tossed my cookies!
sixnotfour
Jun 23 2019, 01:35 PM
latest modern adaptation of a classic Porsche design by DynamicSpeed AutomobilDesign. The Cookie Cutter never looked so good. The forged DS5.5 CC is available in following sizes:
7,0 x 17 - 15,0 x 17
7,0 x 18 - 15,0 x 18
7,5 x 19 - 15,0 x 19
8,5 x 20 - 15,0 x 20
9,0 x 21 - 15,0 x 21
9,0 x 22 - 15,0 x 22
73-914
Jun 23 2019, 02:10 PM
I Like them
1970-1914
Jun 23 2019, 04:41 PM
Those are fantastic - especially the wider they get the better the centres look!
Maltese Falcon
Jun 24 2019, 12:48 AM
Streets of Willow Springs
Bleyseng
Jun 24 2019, 07:49 AM
Mine when it had cookies
ManuFromParis
Feb 1 2021, 03:47 PM
Are all wheels from these pictures 6" or 7" ?
I thought the 7" ET23 were a bit tight within the fender on the rear axle ?
Feb 1 2021, 03:58 PM
QUOTE(ManuFromParis @ Feb 1 2021, 04:47 PM)
6" fit a stock car. 7' don't or need some sort of work to the fender to fit. Same with Fuchs.
Unobtanium-inc
Feb 1 2021, 07:34 PM
Are they worth more than the other ones?
infraredcalvin
Feb 1 2021, 10:29 PM
Gold powder coat (dirty)
DRPHIL914
Feb 2 2021, 09:36 AM
i have a question for the cookie crew!!
is the back set and off set the same as on the the 15” x 6 and 15”x7” fuchs? or my current 16” set of 6” and 7”, which i want to keep for street i want to get a aero of cookies for A/X, but need to make sure fit is ok. in rear i have 7”x16” on rear with 205/55’s , they fit, i have more room than most narrow body cars in rear.
Olympic 914
Feb 2 2021, 07:05 PM
Here's mine with cookies
Click to view attachmentClick to view attachmentAt Hershey a woman was walking by my car with a box of chocolate chip cookies, Dropped the box and these rolled under my car.....
QUOTE(okkie @ Nov 29 2009, 01:14 AM)
Why don't we see more 914's with cookie cutters installed? Show us some photos please!
Okkie
According to the chart I found (somewhere) here
@914world . I see 15” x 7” will be closer to the fender but read that everyone is saying they will need to stretch the rear Fenders to fit 7” in the rears. Maybe the chart is only for the front wheel and did not see well.
Click to view attachment I know it’s a fairly old topic, but for us new owners it’s money saving material.
I found a set on eBay from autoAtlanta, and really appreciate some feedback on fit from all of you literate guys… I will hate to bend my wheel arches after 50 years of preservation. If it will affect the look of the fender.
Click to view attachment I Really need fo fix my cars wheel fitment
Thanks for your comments.
r_towle
Mar 8 2023, 06:33 PM
QUOTE(Unobtanium-inc @ Feb 1 2021, 08:34 PM)
Wth is that?
Did you toss all those wheels?
infraredcalvin
Mar 12 2023, 06:16 PM
@CCE That chart above is for Fuchs, not cookies..hence the Fuchs part number to the right…
Yes the 7” cookie gets the tire close to the fender on the rear, Ive seen people only able to fit a 185 tire with 7” cookies on the rear. 6” cookies give you a bit more room. I had the rear fenders stretched on my car to fit 225s on 7” cookies, see post 75 above.
Also cookies are pretty cheap and plentiful, you can get a decent set for less than half that AA price, check the bird board. Get a set that needs refurb even less, shoot I’ve got some I need to get rid of…
Mar 12 2023, 06:22 PM
I have 6x15 cookies with 205/60/15 tires on a stock, narrow body car. Fit is perfect. 7’s would be too wide on my car unless I went with narrow tires but that would look silly.
mskala
Mar 12 2023, 06:55 PM
QUOTE(infraredcalvin @ Mar 12 2023, 08:16 PM)
It doesn't matter as 6x15 and 7x15 cookie cutters match the offsets of the 6x15 and 7x15 Fuchs.
CCE
Mar 27 2023, 09:20 PM
QUOTE(mskala @ Mar 12 2023, 06:55 PM)
Thanks
VaccaRabite
Mar 28 2023, 06:05 AM
I got a set of cookies years ago (I think from Kevin) that I'm planning to use on my car when I go 5 lug. But its been so long I don't remember what size they are. I bet they are 7s.
I also have fender flares that I can weld on one day. You know, way later then now. When the bus is done, and maybe the dune bug too. Then I can weld flares and re-paint the 914. It will be a whole different car!
Zach
Jamie
Mar 28 2023, 01:43 PM
QUOTE(Olympic 914 @ Feb 2 2021, 05:05 PM)
You mean she dropped her cookies while checking out your cookies?
CCE
May 23 2023, 02:07 PM
QUOTE(r_towle @ Mar 8 2023, 06:33 PM)
Wth is that?
One of those beautiful third world problems, my original set was stolen, from the refurbishing shop. The person who was going to fix and paint them had a better idea for the use of my wheels, and just told me he lost them, so I had to buy a set of VW beetle rollers meanwhile, nice isn’t it.
A friend told me it was my fault
, I should of just give them 2 first…
Here an image of my “now lost” original set. (I kept the center caps)
Nate W
May 23 2023, 06:40 PM
Click to view attachment Engine isn’t in car yet for weight, not sure these 7s are going to work out. Thinking of trying lower profile tires or possibly removing rear camber adjustment plates to make them fit.
Literati914
May 23 2023, 11:12 PM
QUOTE(CCE @ May 23 2023, 03:07 PM)
Unless you need the extra tire for HP reasons -you should seriously just do this ^ again, IMHO
gnomefabtech
May 25 2023, 02:37 PM
I love those wheels too. Anyone know how much they weigh? I'm guessing they are about the same as Fuchs?
I'm looking for a set of 15x7 for my 73 right now.
MedFly914
Feb 2 2024, 11:24 AM
QUOTE(yeahmag @ Jun 22 2019, 10:32 PM)
burton73
Feb 2 2024, 03:48 PM
---On the bird---
Craig's right, 7x15 cookie cutters weigh essentially the same as 7x15 Fuchs. The cast wheel is not as strong as the Fuchs, but stronger than most other cast wheels on the road - it was made by ATE and had to pass much stronger German industry tests (TUV).
So that is it, I know that cast is not as strong and some finishes are not as good on cast material but they seem like they a very good wheels
Best Bob B
