QUOTE(eitnurg @ Dec 20 2009, 02:26 AM)
Undoubtedly different, but not the reason. A boxer has a seperate crankshaft throw for each cylinder, so each pair of opposed opposed pistons are at TDC and then BDC etc simultaneously, like clapping hands. An inherently well-balanced design. A vee has a common crankshaft throw per pair of cylinders, which at 180° are directly opposed, so when one is at TDC its counterpart is at BDC. Not well balanced at all, but it does gain a shorter crankshaft, useful if dimensions have to be kept tight.
An important feature to be inherently balanced in a 4-6 cyl engine when opposed, less so a problem with more cyls. to balance things out overall in 8, 10, 12, 14 & 16 cly racing engines - not to mention that racers are more forgiving of vibration than in a passenger/street car for general consumption.
The "180 vee" would allow for more cyls. to be crammed in a particular crankshaft & case length as you noted.
So Mezger's
thinking on approaching the engine design on both this 917 racer, & on boring & stroking the H-4 914-2.0 were similar, in that he had to squeeze crankshaft modifications in to accomplish the increased displacement in both cases - if applied in the 90 degree opposite axis in each case (per the quote which TC posted above).
From an engine engineering perspective, is this approach of Mezger's similar to what folks like Raby, FAT Performance, etc. are doing to gain stroke & displacement in the up-built Type IV's, or are they doing it purely based on increasing the bore?
In either case, it's important to note that Mezger opened up a whole new era of expanding upon the H-4 engine's displacement & performance by applying Porsche's racing technology to the lowly VW 4-banger!
IMHO the better materials in bearings, etc. & smaller crank created a smoother & more reliable engine as well, since the 2.0's tend to last longer between overhauls than do/did the 1.7/1.8 "standard" type IVs.
I got about 150k out of my 73 2L & could've eked another 20-50k out of it (according to my mechanic Hans), whereas all my buddies with 1.7's back in the day would be rebuilding at 100-120k, as my mechanic Hans always reminded me over the years.
I think it was also due to the fact that the little HP & Torque increase of the 2.0 over the 1.7 made it so that you didn't have to work the engine quite so hard to drive it like a Porsche.
